Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-12-2007, 10:48 PM   #1
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Default [lotza pics] I blame my latest mod on forum member...
jdmvette (thanks mang!!!)
see posts #66 & #81 for an update
During a recent forum thread about radar detectors, he just happened to take a pic of his C5 interior ... and include the fancy mirror he installed (sneaky camera-man... )
ref: http://forums.corvetteforum.com/1560662546-post2.html
I started looking at the available rear-view mirrors with Homelink built-in, and found quite a selection available. All seem to be made by Gentex (Johnson Controls).
The very basic ones are all electronic dimming. Then from there you can add:
*Homelink (garage door opener)
*Compass
*outside temp
*OnStar (extra module required, very expensive)
or any combination of. I also learned that any 2006 or newer model Gentex mirror will do the rolling-code type garage door opener (which I have); and before 2006 some wouldn't
The factory mirrors wiring harness for my 2002 coupe already had the needed feeds; ground, 12v constant, 12v switched, and dome light (the dome light importance will be discussed later).
Only if I opted for the Gentex mirror with the temp display would I need to run extra wires. I decided against the temp display; just a personal preference. So, that narrowed down the search a little...
*electronic diming
*Compass
*Homelink
then I discovered that you can get the compass (and temp display) in various colors... amber, blue, red, green. I chose blue, so this further narrowed down my search.
New Gentex mirrors with electronic dim, compass, and Homelink run $300 to 350 WAY TOO MUCH for me, the "cheap bastich"
I then discovered that's there's quite a market for used mirrors. Many high end vehicles come with these mirrors from the factory. A lot of people take them out of wrecked vehicles and sell them on eBay.
The one I purchased on eBay was out of a 2006 Toyota Tundra (if I remember the ad correctly). The seller included a new universal wiring harness (very important, as the connector is unique and you won't find then anywhere)... for $200 shipped.
here's the new and original mirrors:
closeup of the Gentex:
first three buttons are for 3 different garage door codes, and/or homelink lighting (between #2 and 3 is an indicator led). Then another indicator LED, then an auto-dim on/off button, and last a compass button.
top view comparison
bottom view:
as you can see, the factory mirror includes the interior dome lights on the bottom of the mirror (since there's no dome light mounted on the inside of the roof). I anticipated that and modified the Gentex mirror adding 4 brite-white LED's to the bottom of the case:
remember that little yellow LED on the bottom of the factory mirror that everyone discovers and then posts about ???
I added one of them too
yep; it wasn't easy taking the Gentex mirror apart, but there was plenty of room in the rear case to add the LED's and route the wires.
I connected the dome brite-white LED's to the factory mirror dome light wire, and the yellow LED to the switched 12v wire.
Looking at the bottom with the dome-LED's activated:
yellow LED illuminated:
Installed in my 2002 Coupe:
I calibrated the compass, and then programmed the garage door opener... all worked perfectly. Couldn't be happier.
Here's a crude video of the electronic diming feature in action. I start out wth the auto-dim forced off, then with my hand covering up the light sensor, I re-activate the auto-dim.
http://www.tim-yvonne.com/mikemercury/mirror/mirror.mpg
I did some prelim testing with the brite-white LED's... and decided that 4 of them almost equalled the factory dome lights located in the original mirror. These were cheap 99 cent All Electronics LED's. I know there are even brighter ones available, but the cost would of almost trippled; and the amount of courtesy light from these 4 is more than adequate.
I always had my garage door opener on the floor, always fumbling around to find it.
NO MORE !!!
Mike Mercury is offline   Reply With Quote
Old 08-12-2007, 10:50 PM   #2
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Wow that looks great and you did a wonderful install on that cool looking mirror
peter pan is offline   Reply With Quote
Old 08-12-2007, 10:53 PM   #3
SS~7
CF Senior Member
SS~7's Avatar
Congrats! That's a cool mod! My vert already had one installed when I bought it. You do very good work!
SS~7 is offline   Reply With Quote
Old 08-12-2007, 10:54 PM   #4
Mike Mercury
CF Senior Member
I forgot to mention that the power-on default mode is the auto-dim and compass activated.
The Homelink functionality is connected to the constant 12v feed; so it works whether the key is on or off.
Old 08-12-2007, 10:57 PM   #5
MR.WaynesWorld
CF Senior Member
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
MR.WaynesWorld's Avatar
Location: The real question is; When you turn your car on, does it return the favor..
Send a message via MSN to MR.WaynesWorld
Nice mod Tim....
MR.WaynesWorld is offline   Reply With Quote
Old 08-12-2007, 10:57 PM   #6
sneakelman
CF Senior Member
St. Jude Donor '08-'09
Send a message via AIM to sneakelman
Man I love DIY enginuity! Awesome job!
sneakelman is offline   Reply With Quote
Old 08-12-2007, 11:02 PM   #7
lil vette
CF Senior Member
lil vette's Avatar
I like the remote garage feature, don't need the compass.
if freeway says, south bound, im good.
lil vette is offline   Reply With Quote
Old 08-12-2007, 11:02 PM   #8
C5Dream2004
CF Senior Member
C5Dream2004's Avatar
Tim, Great write up - cool mod. I always enjoy your information/mod info's you put the time in so things are very clear and illustrated so well!!
C5Dream2004 is offline   Reply With Quote
Old 08-12-2007, 11:04 PM   #9
0bigGdaddy
CF Senior Member
bigGdaddy's Avatar
Nice mod
bigGdaddy is offline   Reply With Quote
Old 08-12-2007, 11:08 PM   #10
yaknow
CF Senior Member
yaknow's Avatar
Quote:
yaknow is offline   Reply With Quote
Old 08-12-2007, 11:19 PM   #11
BuckyThreadkiller
CF Senior Member
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
BuckyThreadkiller's Avatar
Location: Top of the hill, 3rd mailbox on the right. Texas
That is a truly great mod.
One question -
Did you mess up the box your iPhone came in, doing all the rewiring on the mirror?
Kidding, only kidding.
BuckyThreadkiller is offline   Reply With Quote
Old 08-12-2007, 11:22 PM   #12
c5 BearsFan
Supporting Vendor
c5 BearsFan's Avatar
that looks great! nice mod
c5 BearsFan is online now   Reply With Quote
Old 08-12-2007, 11:23 PM   #13
jrose7004
CF Senior Member
jrose7004's Avatar
That's sharp!
jrose7004 is offline   Reply With Quote
Old 08-12-2007, 11:29 PM   #14
96cobrakid
CF Senior Member
Send a message via AIM to 96cobrakid
very very cool! i love the mirror
96cobrakid is offline   Reply With Quote
Old 08-12-2007, 11:33 PM   #15
IMXCITD
CF Senior Member
IMXCITD's Avatar
Cool mod!
IMXCITD is offline   Reply With Quote
Old 08-12-2007, 11:33 PM   #16
R Devil
CF Senior Member
R Devil's Avatar
Send a message via Yahoo to R Devil
Wow.Great work.
R Devil is offline   Reply With Quote
Old 08-12-2007, 11:35 PM   #17
Ol'55
CF Senior Member
St. Jude Donor '08-'09-'10
Ol'55's Avatar
Location: Southern New Jersey, The wet part at the bottom
I like it!
Ol'55 is offline   Reply With Quote
Old 08-12-2007, 11:36 PM   #18
Z06-JIM
CF Senior Member
Cruise-In VII Veteran
Z06-JIM's Avatar
Awesome mod and nicely done...
__________________
__________________
Link to Pics:...... http://jlss.smugmug.com/gallery/1912746_M8rFF
Z06-JIM is offline   Reply With Quote
Old 08-13-2007, 12:36 AM   #19
spiral04
CF Senior Member
spiral04's Avatar
Very cool
spiral04 is offline   Reply With Quote
Old 08-13-2007, 12:53 AM   #20
NAVY08
CF Senior Member
NAVY08's Avatar
Send a message via AIM to NAVY08
wow, great work very clean install
NAVY08 is offline   Reply With Quote
Reload this Page [lotza pics] I blame my latest mod on forum member...
Tags
az, brightest, compass, corvette, dome, gentex, install, light, onstar, phoenix, temp, wonstar
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
