4 18" rims all the way around?
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Lots of members are running 18's all the way around. Many are using the CCW's for exactly that purpose.
No problems with the suspension.
Alignment can be done.
tire size?
oh man that is great!
then i am going to get 18's and run some track tires on 'em!
Maybe i can get away with rotating 'em and squeezin' a few more miles out of 'em
thx for the reply !
whats the biggest ( or tallest) tire size you can run on front with 18's?
thx for the reply !
Received 19,446 Likes
'20-'21-'22-'23-'24
You just need to be sure you keep the stagger between the front and rear wheels - can be done by selecting the right size tires.
Does the stagger have to be the exact same ratio as stock or does it just have to be a little bigger in the rear?
I was thinking of running stock 18s front and rear with fatter tires in the rear.
[QUOTE=ryoder;1559359548]Does the stagger have to be the exact same ratio as stock or does it just have to be a little bigger in the rear?
Several members are running the same size front and rear with no problems but others have had gotten some codes. I try to maintain at least a 1/2 inch between front and rear
I'm running 275/35/18's on the front and 335/30/18's on the rear. These are on CCW 505a's with 18x10 inch fronts and 18x11.5 inch rears. Make sure your tire sizes fit the selected rim width for optimum performance, ride and handling.
diameter of the wheel only matters if it clears the brakes or not.
I've run
front - rear
245/45-17 - 275/40-18
265/35-18 - 295/35-18
275/35-18 - 295/35-18
275/40-17 - 315/35-17
295/35-17 - 315/35-17
I've run
front - rear
C5 General
Location: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
F 265 35 18
B 275 40 18
I like all 18s and the 18/19 combo to.
The wheel offset matters to. +/- The tires may rub or stick out
you will want to look into that. This link is very helpfull.
http://www.1010tires.com/WheelOffsetCalculator.asp
Paul G.
B 275 40 18
Paul G.
If you're going to stagger (as has been advised) you won't be doing any rotating. Even if you don't stagger you can still only rotate front to back (same side) becasue of the directional tread pattern.
rotating front to back would be just fine with me!
rears usually go first
if you blow one tire can have a spare that fits on all 4 tires
when you guys say stagger, you are talking about the difference in the width front to back right? not in the alignment correct ?
stagger to me means a crooked line
any of you guys run road courses with same size tires with any luck? or is it better to stagger the sizes front to back?
it would be nice to just carry one spare in the trunk to the track
whats the widest tire you can run on the old GM N37 Magnesium 18" rims?
Location: 90% of all Fords are still on the road.....the other 10% actually made it home!
Originally Posted by rustyguns
staggered to me means a crooked line
If you want to the same size tires front and rear because of rotating issues, I would suggest you go with 275/53/18 in all 4 corners. JMO
I run 275/35/18 front.....and 295/35/18 in the rear. That's only until I receive my 305/35/18's though.
