Tire height, speedometer question [rim change]
Hey dudes,
Running stock wheel and tire sizes for a C5 and I want to change to a 18/19 set up. Finally ditching the chrome bling wagons , due to there not being a 18/19 replica set available.
Basically, if I put C6 size tire and rim sizes - will there be any speedometer modifications?
Here's the complicated version... since I currently have a 45 profile and a 17 inch rim & a 40 profile and a 18 inch rim... if I change to a 40 profile and 18 inch rim & a 35 profile and a 19 inch rim, there should be no speedometer modifications right?
Thanks guys and have a great weekend
Received 1,403 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
Try this to help you out..
This little calculator will give you the answer you are looking for
Tire Size Calculator
1 Post
St. Jude Donor '06-'07
By using that calculator.
The OEM fronts on a C5 coupe and C6 coupe are BOTH the same diameter. 245/45x17 & 245/40x18
The rear diameters are very close, C5 at 26.7, C6 at 26.9
275/40x18 & 285/35x19
