Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-15-2007, 01:15 PM   #1
FLORIDA
CF Senior Member
St. Jude Donor '07
FLORIDA's Avatar
Default Rotors without rust? Recommendations?
Rotors without rust? Recommendations? After I wash my car the rust drips from the brake rotors and makes a rusty mess in the center of my wheels. I am planning to replace my rotors. What is recommended that will not drip rust?
FLORIDA is offline   Reply With Quote
Old 02-15-2007, 01:22 PM   #2
VET IT B
CF Senior Member
VET IT B's Avatar
bear Eradisprrd or at least something zinc washed. Mark
VET IT B is offline   Reply With Quote
Old 02-15-2007, 01:22 PM   #3
87SAM
CF Senior Member
87SAM's Avatar
You can either paint the hats or get zinc coated rotors.
__________________
2012 Cyber Gray GS
87SAM is offline   Reply With Quote
Old 02-15-2007, 01:24 PM   #4
Stangkiller
CF Senior Member
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Stangkiller's Avatar
Send a message via AIM to Stangkiller
Buy a cheap set of napa rotors and paint them with some high temp paint before installing them.
Stangkiller is offline   Reply With Quote
Old 02-15-2007, 01:55 PM   #5
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
I have a set of Baer Eradispeeds on mine and they are zinc coated - been there for around 3 years and no rust. Sportbrakes makes a set of zinc coated rotors that are less expensive than the Baers if you don't want to spend that much. Finally, you can always paint the hats and vents on your existing rotors with a good quality paint and stop the rust.
Vetteman Jack is online now   Reply With Quote
Old 02-15-2007, 02:45 PM   #6
c3andc5
CF Senior Member
c3andc5's Avatar
You have three options:
1. Buy zinc coated rotors
2. Paint the hats with a high-temp paint
3. Get the hat covers like Ecklers sells. They have chrome, painted, or unpainted. If you go this route, I highly recommend that you treat the surface of the rotor hats with a metal rust inhibitor first, otherwise they will rust beneath the hat covers. Don't use the rust inhibitor on the area that the pads contact because most of those products change the color of the metal to a grayish black.
__________________
2000 Torch Red Coupe
c3andc5 is offline   Reply With Quote
Old 02-15-2007, 04:05 PM   #7
jon c
CF Senior Member
jon c's Avatar
best option for no rust is any Zinc coated rotor
jon c is offline   Reply With Quote
Old 02-15-2007, 04:42 PM   #8
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
Zinc dipped is the key!
jrose7004 is offline   Reply With Quote
Old 02-15-2007, 05:17 PM   #9
HollywoodFRC
CF Senior Member
HollywoodFRC's Avatar
Default A cheap solution
I painted the hats on my rotors with high temperature paint ($12.00 for two cans of Duplicolor). Then, each time I wash my FRC, I dry it and buff it as normal, wipe down the engine compartment, buff my chrome wheels, then take her for a short spin applying the brakes frequently, not hard just touching. Heats up the rotors a little, water evaporates, whisks away any surface rust on rotors. Takes 5 minutes. Put her in the garage. No rust issues. Just a suggestion. Only costs the cost of 1 mile of gas.
HollywoodFRC is offline   Reply With Quote
Old 02-15-2007, 08:20 PM   #10
RonJ
CF Senior Member
RonJ's Avatar
My suggestion is paint the hats with a good high gloss black enamel. Doesn't have to be high temp paint, hats don't get that hot on a street driver.
Cheap, easy, looks good, won't rust. What more can I say!
RonJ ...
RonJ is offline   Reply With Quote
Old 02-15-2007, 08:33 PM   #11
Stangkiller
CF Senior Member
RonJ ...
Not that hot?! Go for a drive and put your hand on your rotor
Old 02-15-2007, 08:35 PM   #12
jasons0147
CF Senior Member
jasons0147's Avatar
Send a message via AIM to jasons0147
jasons0147 is offline   Reply With Quote
Old 02-15-2007, 09:18 PM   #13
waunavet
CF Senior Member
waunavet's Avatar
Quote:
Do you know if any of our dealer friends have zinc coated rotors? Does Delco offer them?
waunavet is offline   Reply With Quote
Old 02-15-2007, 09:21 PM   #14
Vega$Vette
CF Senior Member
Vega$Vette's Avatar
Sportbrakes
Click the image to open in full size.
Vega$Vette is offline   Reply With Quote
Old 02-15-2007, 09:26 PM   #15
bowtie1978
CF Senior Member
bowtie1978's Avatar
Zinc Coated
bowtie1978 is offline   Reply With Quote
Old 02-15-2007, 09:35 PM   #16
RonJ
CF Senior Member
RonJ's Avatar
Quote:
No, not that hot.
I wouldn't put my hand on the rotor itself, but on the hat I might .....
RonJ ....
Old 02-15-2007, 09:48 PM   #17
CorvetteSteve
CF Senior Member
CorvetteSteve's Avatar
Quote:
Originally Posted by Vega$Vette View Post
Sportbrakes
Man that set-up really looks nice!!
CorvetteSteve is offline   Reply With Quote
Old 02-16-2007, 12:13 AM   #18
sprk33
CF Senior Member
Support Corvetteforum!
sprk33's Avatar
Send a message via Yahoo to sprk33
I taped them off and painted them high temp paint. Turn out real well. Here is a pic.
sprk33 is offline   Reply With Quote
Old 02-16-2007, 02:24 AM   #19
Rocket02
CF Senior Member
Rocket02's Avatar
Ok, I tried this and even at 20mph, I can barely reach the rotor. Then with my friends help, I finally managed to do it, while he steered. You're right its hot and fast.
signed ....Lefty
Rocket02 is offline   Reply With Quote
Old 02-16-2007, 10:16 AM   #20
Vega$Vette
CF Senior Member
Vega$Vette's Avatar
Quote:
Thanks They have been on my Vette for about a year now
__________________
Reload this Page Rotors without rust? Recommendations?
Tags
good, inhibitor, rotors, rust, withoutrust
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
