New Message
Old 02-21-2007, 10:31 PM
boyblue97
boyblue97's Avatar
Default New Message
I was driving the vette this evening and the display randomly read something like "service wheel mod. soon" probobly not those exact words i should have paid more attention, but after i reset it it never came back on so should i worry or do you think its ok?? thanks guys
Old 02-22-2007, 12:48 AM
PierEagle
PierEagle's Avatar
Probably said "Check Wheel Monitoring System" (TPS). Check the tire pressure with a manual guage. Set to 29-30 lbs. You said you cleared code. So, wait and see if it comes back again. If it does, check the pressure shown for each tire on the DIC. Remember, the car has to have been moved at about 10-15 mph for the TPS to "wake up". Your profile shows a '97 so there is a possibility, if those are the original sensors, that the battery(s) are starting to go. Take it one step at a time. Repost if it reoccurs.
Cheers
Old 02-22-2007, 01:02 AM
LKGRenegade22
LKGRenegade22's Avatar
Just check your tire pressure and drive. Don't worry about it. If it comes up again just repost.
Old 02-22-2007, 09:38 AM
oldschoolvette
oldschoolvette's Avatar
Old 02-22-2007, 11:31 AM
boyblue97
boyblue97's Avatar
thanks guys i apprichiate it
Old 02-22-2007, 12:52 PM
ptdrummer54
ptdrummer54's Avatar
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
If the tire pressure is low, you should get a message indicating that the pressure is low. If you get a Service Tire Mon system soon, it is most likely caused by your TPS batteries getting weak....
To New Message
Quick Reply: New Message
