battery tender questions
Is there a particular battery tender that most people recommend for long term (7 months) storage?
What companies or forum vendors have the best deals?
Is it better to remove the battery from the car when hooked up to the tender for that long, or is it alright to hook up the tender with the battery still in the car?
Thanks for the help.
I have a battery butler and it works very well.
http://www.lectriclimited.com/battery-butler.htm
Leave the battery in the car with the tender hooked up. Everything is automatic so rest assured that you're in good hands with the "battery tender plus".
Received 1,409 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
I have had great reults with the Batttery Tender Plus 12V. I am using now for my 4th season and has been perfect.
I now use them on 2 different cars. I bouyght a second unit last fall tfor the 2nd car that also sits idle for long periods.
Battery Tender Plus
Battery Tender Plus
battery butler is pretty good-they charge the battery as needed and are good for long term storage. I have been using one for 3 years and no problems.
The Battery Tender does all the work. It is not the same as a trickle charger. The B-T will charge the battery then settle back and turn itself back into charge mode when and if the battery falls down below 80% full charge. It does NOT keep a constant charge going.
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have the deltran Battery Tender weather proof model. I have used it for the past 3 winters. Works great.
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Here you go...
We've sold 300+ of these so far this winter. IMHO they are the
best around.
http://www.customcorvetteaccessories...rycharger.html
Peace
Chip
best around.
Peace
Chip
1 Post
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
been using this for 3+ years - works great and the money I saved (versus others) went to more mods....
http://www.harborfreight.com/cpi/cta...emnumber=42292
I have used the Battery Tender Jr over a few winter months when i Vette sits inside my garage. It works fine in keeping the charge on the battry.
Received 19,441 Likes
'20-'21-'22-'23-'24
The Deltran Battery Tender Plus would be a good choice (I have this one). You do not need to remove the battery from the car - just hook it up and let it be. Does a great job keeping the battery charged up. About $60 from any vendor.
That's what I'm using. Picked up two of them, one for the vette, one for the John Deere!
I have been using a Battery Tender Jr. for the last 2 years on the GTO then the Z. Works as intended, I would recommend it.
walmart has the black and decker unit for less than $20 down here, I have like 5 of them on diffrent things, they also have a cig lighter adapter to make it easy.
More Than Zero
More Than Zero
Thanks photoguy. I am about an hour west of Pittsburgh. Can't wait till nicer weather finally gets here to stay. I have had my car for about a week, and it is killin me to just watch it sit in the garage. Sure is pretty though. :-)
