Ok, so it doesn't look like the Fat Daddy's or the C6 units will fit a 2013 427 vert unless I am not understanding or if I am reading this wrong. So, does anyone know where I can find a set that will?
Not aware of anyone that does...
There are not enough cars to warrant the coat of making them
All FattDaddys are now Powder Coated
High Gloss Bengal Black
The "FattDaddy" was designed and engineered by Custom Corvette Accessories
with strength in mind. The "FattDaddy" uses grade 5 bolts and has and 1 7/8"
polyurethane wheel that can withstand up to 800 pounds of
operating pressure and 1200 pounds of static load.
The "FattDaddy" is a single wheel front clip frame saver that inserts through a
3/8 inch hole you drill in the frame. The "FattDaddy" distributes its load via a
grade 5 bolt, giving you the ultimate in peace of mind and protection for your
Corvette frame.
If you are tired of that horrific scraping sound every time you back out of the
driveway or go over a speed bump, you can protect your front clip from frame
damage like this with the "FattDaddy" .
In our steadfast tradition of "Killing the Corvette Tax, one product at a time"
We are thrilled to offer the "FattDaddy" at an introductory price of
not $99.99, not $79.99, not even $59.99 on sale, but...
