[Z06] Home-made Ramps For The Z
Old 07-05-2006, 02:08 PM
2TONE82
2TONE82's Avatar
Default Home-made Ramps For The Z
I made some ramps for my Z06 so that I can do oil changes at home. I’m a small guy so I don’t need much room to work in, as you can see I gained about 9” clearance at the front spoiler. Also, my floor jack would not fit under the front of the car but will now with the car on these ramps. I’ll use this to take the wheels off. The ramp also doubles for use on the ’82.
The ramps are made out of 1x12’s. I bought one 12 foot length and had it cut in half at the store (Lowe’s). I also bought two 4 foot lengths. Then I used a circular saw to cut the boards at a 45 degree angle. I cut the 6 foot board in two pieces: 3 ½ feet and 2 ½ feet. Flip it over so the 45’s match up. Then align the flat edge of the boards and screw the 3 ½ foot board on to the 4 foot board. Then screw the 2 ½ foot onto the top of that. Mount a “stop” board at the end. I put handles on the sides for ease of movement. Total investment about $25 and I’ll recoup that with my first oil change!
Old 07-05-2006, 04:10 PM
JWB ZO6
Support Corvetteforum!
JWB ZO6's Avatar
St. Jude Donor '06-'07
those will work fine but I thought the car was supposed to be level for oil change.
Old 07-05-2006, 04:28 PM
B R
B R's Avatar
Location: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
Have you ever drained the oil in your car? Probably not, because if you had you would have seen that the oil will drain quite well with the front end higher than the back. I think it actually helps the process given the locations & angles & all .
Old 07-05-2006, 04:42 PM
2TONE82
2TONE82's Avatar
Yes, I've heard/read the same but reasoned that you're not going to get all of the oil out no matter what you do...and I'm putting the same stuff back in; new of course.
I've actually heard of a guy that lets his drain OVERNIGHT...and I thought I was over the top .
I'm close to my first oil change, if it looks like oil is trapped in the motor because of the angle I'll just lift the rear with my floor jack to level out the car; although I don't think that will be a problem.
Old 07-05-2006, 05:05 PM
FasterIsBetter
FasterIsBetter's Avatar
Nice idea, but for about $25 you can buy a set of Rhino ramps that work just fine. Plus, they are very light weight (relative to those heavy boards), and they stack. So, youz pays your money, youz makes your choice, as they say.
Old 07-05-2006, 05:07 PM
Comin' Thunder
Comin' Thunder's Avatar
That looks really good. I think I'm going to build some of those for myself this weekend. Maybe a set for the back also to get the car level. Thanks.
Old 07-05-2006, 05:10 PM
Comin' Thunder
I have Rhino Ramps that I used for my lowered Camaro SS that worked great. My Z cannot get up them due to the front bumper guard scraping. I loved my Rhino's, but had to use wooden planks to get up them.
Old 07-05-2006, 05:12 PM
2TONE82
2TONE82's Avatar
I call ...show me the low profile Rhino ramps for about $25. Best I could find was 49.95...that's where the "I can make that" came in. Granted, the boards are heavier but the footprint (laying down or standing up for storage) is the same. Hey, I'm not "Bubba" but I do live in AL, I was a Marine for 20 years - doing more with less in my thing!
Old 07-05-2006, 05:17 PM
briann510
briann510's Avatar
I had my car level for an oil change, and when it was done dripping out, I jacked up the rear about another foot and got some more out. So having it level does NOT get the max amount out of the pan.
Now I have a open bed car trailer and just drive up on it for oil changes and what not and it was well worth the price. Im sure glad I didnt buy a solid floor trailer!
Old 07-05-2006, 05:18 PM
briann510
briann510's Avatar
I bought a set of new Rhino ramps this year on Ebay for 19.95 plus $15 shipping.
Old 07-05-2006, 07:13 PM
Tact
Law Dawg Moderator
Tact's Avatar
CF St. Jude Co-Organizer
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Actually the rear needs to be a little higher than the front for complete and proper drainage. I drive mine on ramps then jack the back up with a floor jack. It doesn't take much more time or effort to jack the back. I just want as much of the "old" oil out as I can get.
Old 07-05-2006, 07:35 PM
EBZ0602
EBZ0602's Avatar
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
I do think that the car is suppose to be level for draining the oil, but if anything the rear needs to be alittle higher than the front, if I remember correctly the drain pllug is in the front of the oil pan
I have your ramps, but just the two stage, just so that I can get my jack underneath to jack it up For me its two jacks and four jack stands
EBZ0602
Old 07-05-2006, 07:48 PM
JB666
JB666's Avatar
Great job! I made a set a couple of years ago for my lowered '95. I put hooks on the top - They hang on my garage wall when they aren't in use... The car doesn't scrape, and I have 4 "levels" I can take it up. VERY easy to use , and you can use them with anything..
Old 07-05-2006, 09:57 PM
JWB ZO6
JWB ZO6's Avatar
Yes, I have but I have a four post lift. It is level and I just let it drain till stops and fill her back up. If you have a better way more power to you.
Old 07-05-2006, 10:02 PM
Tact
Law Dawg Moderator
Tact's Avatar
Old 07-05-2006, 11:12 PM
mqqn
mqqn's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Tact -
I agree - although it works level, just takes longer to drain completely.
I use a lift as well, and I don't sweat the approx. 1 or 1.5 fluid oz that would potentially remain in the crankcase from a "level" drain and fill.
Probably would want to jack the rear up if I used the ramps that 2TONE82 made (very nice ramps, btw... )
best regards -
mqqn
Old 07-05-2006, 11:27 PM
Tact
Law Dawg Moderator
Tact's Avatar
Originally Posted by mqqn
Hi Tact -
best regards -
mqqn
To Home-made Ramps For The Z
Old 07-06-2006, 12:04 AM
Shylor
Shylor's Avatar
I also paid $25 for my Rhino Ramps (Wal Mart). They work great and didn't cost me any time in making my own.
Old 07-06-2006, 12:32 AM
Hatdude
Hatdude's Avatar
I made some wooden ramps like that a few weeks back, one for each tire in fact so I could get the entire car up. After a dozen or so attempts I gave up. The dang things wanted to slide all over my garage floor. I'm not the type to take wasting time lightly. .. couple hours later I have a KwikLift on order. :p
In the end though, if those work for you, awesome! Good luck and be safe.
Old 07-06-2006, 01:06 AM
Marine
Marine's Avatar
What you have there Marine is something most won't understand and others will doubt.
Something that stands up to the job with next to nothing and does it for even less.
But then again I don't have to tell ya that.
Quick Reply: [Z06] Home-made Ramps For The Z
