[Z06] 03 passenger window won't go down
Just tried it and I can hear the motor click but it won't move. I've tried both driver and passenter switches and "helping" it down with my hand with the door open. Any ideas?
Motor could be hung up... try pounding on the door panel while holding the switch (dont pound so hard as to damage anything) see if it frees up (had a similar problem with a 1992 vette I had years ago). if that doesnt work you may want to pull the door panel and have a look
I had the similar problem. I took my door apart and found that the cable for the window system had come off and was hung up on a bolt. It was a pain to get back on but everything works great now.
