anyone have similar C5 problems...
i am taking in my 2001 (under 6 year warranty) for some repairs, just checking if anyone has had these problems:
1. on my HUD, the "oil can" stays on all the time (the container with the drop on the right side) - in the manual, i think it says that this icon indicates an oil pressure problem, but the mechanics have said this that oil pressure is not an issue with the car (just a "jammed" HUD problem). anyone else had this problem? i want to push them to fix the HUD this time.
2. the passenger window does not roll down using either the driver contros or passenger controls. anyone else had this problem?
i get charged a $200 deductible every time i take it in for repairs, so i am trying to learn as much as i can about these problems, and hopefully their fixes, before i take it in.
thanks much for any replies/advice.
-Bill
-Bill
re: the passenger window does not roll down...
Unfortunately, this is a very common problem. So common, that when I brought my Vette in last week for this repair, my local Chevy dealer told me they don't have to order the window motor parts - they keep them in stock all the time due to the frequency of the problem.
You would think that the manufacturer of the greatest car in the world would learn how to make power windows that work reliably.
David
David
C6 of Year Finalist (stock) 2019
I assume you have read the manual on how to change the icons on the HUD. That one comes on if i set it to come on and the bars give you an oil pressure reading. If it is the only one that will come on when you try to change the settings your HUD probably needs fixing...maybe just the switch...
Window could be just the switch too. Think the automakers all buy cheap switches now days.
Good luck
Good luck
Cruise-In VII Veteran
The "oil can" is for oil pressure, if there are no bars next to it when the car is on, you're in trouble. You can switch the HUD to show your other data, press or hold the HUD control button.
MONARTOR
what does the oil pressure gage show??
You can change the information displayed in the HUD by pressing the "Page" button on the upper left side of the dash. It will change to show the fuel level, amps, oil pressure and perform a few other tricks for you.
The passenger side window deal is a common problem. There are several threads on it, do a search on "passenger side window"
I thought holding the window down button down and slamming the passanger door sometimes fixed the window issue? I don't have the problem but I've read the fix here before....
-Bill
-Bill
Thank goodness, when it got stuck again, it was in the up position.
David
