Help.....I dropped a socket in the engine compartment
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by blacksedan87
OMG!!!! You dropped a tool into the BLACKHOLE??
The last person that reported that problem reached down there with a magnetic extending wand and his arm disappeared!
You've heard of the Bermuda Triangle, right? Well, this is the Corvette Triangle.......
Tools have a way of mysteriously disappearing into it - never to be heard from again......
Actually - now that I've gotten that out of my system - I really did use one of those magnetic extending wands and I was able to snag it. Here's a pic of what's in that hole......
Happy hunting!
Happy hunting!
Well, I followed the directions above to try and retreive my battery terminal hold-down nut. I found I had to remove the wheel for easier access.
I searched inside there, but did not find it.
I'm glad you other guys had more luck
Worse Problem
A bunch of years ago I was helping a friend install new solid lifters in his '67 427 & we dropped a small bolt into a lifter bore. Luckily, we were able to see it & eventually retrieved it with a magnatized screwdriver.
Happy hunting!
Happy hunting!
Thanks everybody.....you guys are the best!!!!
Happy hunting!
Happy hunting!
Happy hunting!
Happy hunting!
Don't feel bad. Went to take out my battery today and dropped the first damn socket I tried on the bolt head. Had to jack her up, remove the wheel, and open the panel just to get in there.
However, thank you. If I hadn't seen this thread a couple days ago, I'dve never known how to access that low area.
Originally Posted by JDs00PewterCoupe
I've done the same thing with a socket and taking this panel off made access very easy. There is not hole for the socket to fall out, so if you want it, follow the above.
Originally Posted by C5MILLYELL02
BlackSedan87 You didn;t have to take your fendor off just to show where it was
#33
OMG. I thought I was the only one this had happened to! I've droped two sockets into that dang abyss. They have been there for years. I thought I'd never see them again. I can't thank you guys enough for all the info you share.
