drivers side window is not working thanks stan !!!!!
Old 04-02-2006, 02:50 PM
sts57c5
sts57c5's Avatar
Default drivers side window is not working thanks stan !!!!!
My drivers side window had stopped working so yesterday my friend took the door panel off tapped the regulator a couple of times and it started back to working. THanks Stan you are the man dont forget your beer is on the way!!!!!! thanks.
Old 04-02-2006, 04:29 PM
WWK888
WWK888's Avatar
It is giving you a warning sign that it is about to crap out for good.
Old 04-02-2006, 08:45 PM
sts57c5
sts57c5's Avatar
ok we will see
Old 04-02-2006, 09:21 PM
randy ransome
Support Corvetteforum!
randy ransome's Avatar
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
Mine does it all the time. I've replaced both window regulators and they still do it from time to time. When they quit working I just hit the door panel hard while pushing the window button. They'll usually work again for a while.
Old 04-03-2006, 02:30 PM
sts57c5
sts57c5's Avatar
thanks
Old 04-03-2006, 03:23 PM
BrianWe
BrianWe's Avatar
I will give this a try as my passenger window is not working.
Old 04-04-2006, 01:03 AM
Wisdom
Wisdom's Avatar
This link seemed to have worthwhile discussion on this topic.
- Wisdom
Old 04-04-2006, 09:27 AM
sts57c5
sts57c5's Avatar
- Wisdom
just an update my window stopped working yesterday afternoon. I dorve my car to work parked it went in the building , when i got off work it was not working . The temp yeserday was in the 70s. This morninh when i was leaving the health club at 6am it started back to working again. the temp was in the 40s this morning.
Old 04-04-2006, 09:28 AM
sts57c5
sts57c5's Avatar
does anyone have part number for drivers side window regulator if so pls email it to me at nateboclair@aol.com pls thanks.
Old 04-04-2006, 09:31 AM
c5BlackBeauty
Corvette C5 Enthusiast
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
- Wisdom
Thanks for the link. Some good info.
Old 04-04-2006, 11:46 AM
sts57c5
sts57c5's Avatar
part number is 10338548 and cost at dealer for the part is 280.00
Old 04-04-2006, 12:11 PM
Blindfingers
Blindfingers's Avatar
Its most likely not the regulator but the door control module. The relay for window up/down is shot. Check in the C5 Tech section and you'll find a fix for just a couple of bucks.
Bob
Old 04-04-2006, 02:39 PM
RPHCRMZ51
RPHCRMZ51's Avatar
That is the same thing that happens to me all the time. Living in Houston it is pretty warm 24/7. I now can remove the bottom right hand side of the panel only and reach in with the end of a big screwdriver and give it a wack. Works everytime. Takes about 5 minutes now.
Old 03-24-2010, 04:28 PM
sts57c5
sts57c5's Avatar
wow
Old 03-24-2010, 04:42 PM
WWK888
WWK888's Avatar
wow
WTF...four year old thread revived???? Why????
Old 03-24-2010, 04:44 PM
casisthefirst
casisthefirst's Avatar
Old 03-24-2010, 05:44 PM
socalman
socalman's Avatar
St. Jude Donor '10
cuz 'wow'
Old 03-24-2010, 07:02 PM
dobewillie
dobewillie's Avatar
Great info
To drivers side window is not working thanks stan !!!!!
Quick Reply: drivers side window is not working thanks stan !!!!!
