display on dual zone climate control panel is very dim
Old 04-03-2006, 01:57 PM
  #41
Just say n2o
Just say n2o's Avatar
<---- This guy is a dumbass. There always has to be one that takes an easy tech tip and f's it up. I got it all apart and soldered all the resistors, plugged it back in and it worked, sweet!!! About 30 seconds later I smelled smoke and the display went out, WTF So I pull it back out, get it back apart, and low and behold I see a large blob of solder up in the corner of the circuit board underneath it a burnt line in the board. I guess in my excitement to get it put back together I missed that I dropped a blob of solder on the board thereby shorting it.
Old 04-03-2006, 02:49 PM
  #42
RPOZ4Z
RPOZ4Z's Avatar
Cruise-In VII Veteran
Ouch!:o
did you fix the burnt trace?
does it still work?
Old 04-03-2006, 03:00 PM
  #43
Just say n2o
It's boxed up and on it's way to be rebuilt. Hopefully nothing else is fried.
Old 04-03-2006, 05:09 PM
  #44
Winterlude
Winterlude's Avatar
Cool I can't wait to try this!
Old 04-03-2006, 07:09 PM
  #45
REDEVIL
REDEVIL's Avatar
I tried this method and it didn't work. My backlights still don't work on the AC buttons, however the backlight for the display works. Is there something else I should try to fix the bulbs behind the buttons?
Old 04-04-2006, 06:07 PM
  #46
Z06ufgrad2002
Z06ufgrad2002's Avatar
My car goes in to the dealer tomorrow for a new display.
I'll see if they will let me keep the old one to play around with and find a way to repair the button lights.
Old 04-04-2006, 06:14 PM
  #47
usd2sing
usd2sing's Avatar
all of the back lights were out on mine when i sent the unit to mandigital or whatever the ebay guy is.
came back all fixed. same price $45
Old 04-05-2006, 02:19 PM
  #48
0EG@EnglandGreen
Supporting Tuner
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Just soldered mine. Will test and report findings
Old 04-05-2006, 05:04 PM
  #49
Z06ufgrad2002
The dealership replaced the unit but, I was unable to keep the old as they had to send it back to GM. So I won't be able to tear into it and look at the button lights.
Old 04-05-2006, 10:33 PM
  #50
0EG@EnglandGreen
Supporting Tuner
Of course, my HVAC is totally different from all of the others posted. What a surprise.
Still: I soldiered on and soldered all the surface mounted resistors nonetheless.
Success!! Works like new!!
2GOFAST (11-10-2015)
Old 04-06-2006, 04:41 PM
  #51
ryguy84
ryguy84's Avatar
So all I need to get is a soddering iron and some sodder?
Old 04-06-2006, 04:59 PM
  #52
Z06ufgrad2002
Yup
Old 04-06-2006, 05:33 PM
  #53
ryguy84
ryguy84's Avatar
Yup
Thanks Z06! Z06 do you also know where I could find some info to remove the climate control unit? Ive looked but so far no luck. Also what wattage of a soddering iron should I see a 15 watt and 30 watt or the dual? What kind flux solder do I need theres 2 kinds?
Old 04-06-2006, 05:38 PM
  #54
Z06ufgrad2002
There is a good write up here:
http://www.thelapd.com/bezel.htm
Follow these instructions up til the point where the climate control surround is removed. At that point you won't need to go any further.
Then there are just a few screws holding the A/C control unit in and after that you can follow the instructions in this post.
HTH
Old 04-06-2006, 07:51 PM
  #55
RPOZ4Z
RPOZ4Z's Avatar
a 15w pencil should be fine, you want rosin core solder, go to radio shack, they will have everything you need.
Old 04-07-2006, 12:10 AM
  #56
ryguy84
ryguy84's Avatar
thanks everyone for the help cant believe it works. But now I got 2 lights out on the panel the off and auto button how do I fix those?
Old 04-08-2006, 01:12 AM
  #57
YELLO C5
YELLO C5's Avatar
Thanks to those that posted pics. You guys saved me $45. Mine looked like the later pics as well. Tried a Cold Heat iron and touched up the surface mount components only. I have a pretty good idea of which one was really bad since when I hit one end with the iron it slid off the board. Repositioned with pliers and hit it again. I didn't add any more solder. Has been working great all week.
To display on dual zone climate control panel is very dim
Old 04-08-2006, 02:19 PM
  #58
Z06ufgrad2002
Does anyone have a part # on this piece.
I am curious how much a new Automatic Climate Control unit costs.
Old 04-08-2006, 03:20 PM
  #59
RPOZ4Z
RPOZ4Z's Avatar
they are a couple hundered dollars brand new.
Old 04-08-2006, 06:05 PM
  #60
HIVLCTY
HIVLCTY's Avatar
I took mine out and soldered it last week and it works great and I have the satisfaction of fixing it myself. I guess procrastination paid off this time, because I was going to send it off earlier this year, but was too busy. Anyway, just got back from getting new Kumhos MXs' and an alignment, what a difference. Thanks RPOZ4Z for the info. If you're ever in Denver, I owe you a beer
Quick Reply: display on dual zone climate control panel is very dim
