[Z06] trunk lid doesn't "pop up"????
Old 02-19-2006, 10:55 PM
02z06tr
02z06tr's Avatar
Default trunk lid doesn't "pop up"????
Hi guys, This should be an easy one for you guys. When I pop the trunk lid, either with the key fob or from inside, it pops but only opens a little bit, it is hard to get fingers under lid to lift up. I tired lubrication the piston but no change. any ideas??? Thanks, Ed
02z06tr is offline
Old 02-19-2006, 11:03 PM
JETZ
JETZ's Avatar
Slam the door shut, the air preasure will pop it up more.
OR...
JETZ is offline
Old 02-19-2006, 11:05 PM
Beaver06
Beaver06's Avatar
Beaver06 is offline
Old 02-19-2006, 11:58 PM
TheDVS1
TheDVS1's Avatar
A little white lithium grease on the release mechanism solved that problem for me. It's been well over a year now and she still pops just fine.
TheDVS1 is offline
Old 02-20-2006, 12:00 AM
pdqz06
pdqz06's Avatar
OR...
pdqz06 is offline
Old 02-20-2006, 12:14 AM
Dennis Wilson
Dennis Wilson's Avatar
I had the same problem & just sprayed i bit of WD-40 on it [ the lock mechinism] .And it works fine! pops uo about 2 inches now!
Dennis Wilson is offline
Old 02-20-2006, 12:50 AM
Z28STYLE23
Z28STYLE23's Avatar
Originally Posted by pdqz06
Might be stupid but lookin at the pic what are we lookin at to fix this
problem.
Z28STYLE23 is offline
Old 02-20-2006, 01:24 AM
jcraven
jcraven's Avatar
Mine does this too. The guy I bought my ’01 Z06 from has an ’06 Z06…same problem. I normally use the close-the-door technique or gently wedge a key between the deck lid and body to lift it up a bit . I’ll have to try the lithium grease technique!
jcraven is offline
Old 02-20-2006, 02:17 AM
leaftye
leaftye's Avatar
You want something that'll help it pop up a little more??
leaftye is offline
Old 02-20-2006, 02:45 AM
Z06-Goose
Z06-Goose's Avatar
I think that's what he's saying. Mine does the same thing. I'd like to be able to make it pop-up more so I don't have to deal with the shutting the doors trick. It just doesn't look cool.
Z06-Goose is offline
Old 02-20-2006, 04:40 AM
mkiv808
mkiv808's Avatar
How high is it supposed to pop? Mine only pops up maybe half an inch and then I wedge my fingers under it to pull it up.
mkiv808 is offline
Old 02-20-2006, 08:21 AM
RAO-3
RAO-3's Avatar
problem.
Added a spring on the lifting mechanism. This worked for me, but the lube helps too!
Ray
RAO-3 is offline
Old 02-20-2006, 09:40 AM
JoeZ
JoeZ's Avatar
I had the same problem when I first got my Z06...I just sprayed WD-40 in the latch and it worked. Now, a year later, it is starting to stick again so it is time for WD-40 once more!
Also did the WD-40 on the center console armrest hinge which made a world of difference in opening it up.
JoeZ is offline
Old 02-20-2006, 04:26 PM
IsItFast
IsItFast's Avatar
WD40 worked for me too. I may have sprayed a little on the hinges too for that little extra. But I belive the latch is the main problem. Do it about once a year.
IsItFast is offline
Old 02-20-2006, 07:29 PM
02z06tr
02z06tr's Avatar
Thanks guys, as usual one question and a ton of ideas, I can't say enough about this site! I tried the wd40 it didn'twork, the door slam I knew about, but as someone said, it isn't to cool when you are coming up to your car and have to release the latch, open the door, shut the door, open the trunk shut the trunk! i will try the lithium grease. the spring thing will be next. is that just a regular spring from Home Depot?? not a vette part i presume?? Thanks again!
02z06tr is offline
Old 02-20-2006, 07:31 PM
Miguels
Miguels's Avatar
what type of spring it that?
Miguels is offline
Old 02-20-2006, 07:34 PM
Crushinator
Crushinator's Avatar
Cool, I'll have to try that. All three of my Z06's have had this problem and I never knew what to do about it.
Crushinator is offline
To trunk lid doesn't "pop up"????
Old 02-20-2006, 07:44 PM
JETZ
JETZ's Avatar
Not my mod, just reposted a members pic. Looks like what ever you can get a hold of to try, and if it does the job...it's the right one!
JETZ is offline
Old 02-20-2006, 08:11 PM
RaleighSS
RaleighSS's Avatar
Default twisty things
I adjusted the black bumpers on each corner of the trunk lid and mine now opens fine... ya have to play with it a few times... but mine opens up just fine now..
RaleighSS is offline
Old 02-20-2006, 08:55 PM
Z06-Goose
Z06-Goose's Avatar
One quick question...
wouldn't too much WD40 wash away the lubing?
Quick Reply: [Z06] trunk lid doesn't "pop up"????
