[Z06] Best oil or lubes for tranny and rear diff??? ordering tonite need help....
hey what oil or lub should i refill the trany and rear diff with?? anyone??? name and type plz....
thanks how many of each fo i need? im sorry for al lthe questions, maybe it would just be easier if you tell me exactly what to get and how many.. lol i really appricate your help
1 Post
Everyone has their own opinion whats best and some make money on selling certain brands..
I use Redline in the rear and tranny... I bought it from Jegs. 75w90 in the diff.. already has the friction modifiers.. Use ATF D4 in the tranny. Has to be ATF and dexron III compatible if you want to use whats recommended by the manuafacturer.
I have been using redline oil for many years and find it to be excellent, I'm sure the other premium brands also work well..
1 Post
CI 3-5-6-7-8 Veteran
Originally Posted by mkiv808
Sometimes the added viscosity of dino oils is better in the tranny and diff.
Originally Posted by Cobra4B
??? Not when I'm running 30 minute sessions at VIR. I want all the heat protection I can get. On a C5 the transaxel doesn't get much air flow and the exhaust pipes pass directly under it... this can make for a hot trans/dif.
1 Post
Synthetics are better at lubricating and keeping things clean.. they can also can handle more heat which is important in the C5 as the main components don't get much airflow..
Premium Supporting Vendor
Tranny fluid (meets Dexron III standards):
AMSOIL ATF (Product code is ATF)
Takes just under four quarts
Diff fluid (meets GM standards and comes with friction modifier in it)
AMSOIL Severe Gear Extreme Pressure 75w90 (Product code is SVG)
Takes just under two quarts
FYI, I use both these in my Z06 which sees exclusive track use. You can order via the link posted above (thanks Brian), or the info in my signature.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
