How to get rid of "kidney shake"?
O.K. I'm new to Vette ownership myself but not the automotive world. I love my '01 vert and do whatever it takes to keep it in great shape. This car is like a child.. you always love it but at times you want to just knock the living mess out of it. At high speed, there is a surging vibration coming from the back. The stealership claimed they balanced it before I drove it off the lot. Being somewhat intelligent, I took their assurances with a huge grain of salt. And had static and dynamic balances done on all four tires at a reputable tire shop I've been dealing with for years. I still have a vibration in the left rear. Anybody else have this problem or know of a solution?
Thanks,
John
Thanks,
John
Originally Posted by rnengnr
ever check the rotors back there...... it has spinning mass , and if that is out of balance, anything you do off the car wont take that into consideration.......
Originally Posted by DJMRTS
Maybe a wheel bearing is going out?
Seems you may have a little increased noise or hum too at that speed.no?
Received 1,680 Likes
I'm wondering if you have a warped rear rotor.
Received 19,429 Likes
'20-'21-'22-'23-'24
You may also want to have the wheel checked for being bad. Could be bent.
I'll never forget a comment someone made in a class related to dynamics...........
" you can balance an egg but you'll never make it roll straight"
My 91 C4 had low speed vibe from a flat spot I caused in a slide,,,, and set up a vibration around 65mph..... I found the flat spot by using the process below......then I bought new tires
some people refer to "dynamic balancing" as the spinning machine off the car and "static balance" as bubble balance off the car.
If you did an on the spindle balance then you took the rotor into acount....
soooo.... as mentioned in other posts.......
bad Rim, slightly bent spindle , tire slightly out....
I went through the same issue on a car i had a while back and swapped from steel to alum rims and the problem went away..... not to say this is your problem but you can check it with something simple if you can get it in the air.
if you jig something fastened to the ground and lay it against the tire and see if the runout is bad, i would say 1/4" could cause this vibration..
soory abt being so long winded but this problem had me very frustrated in the past and I feel your aggravation,,,,,,,
good luck and let us know what you find
Rick
PM me if you like
Rick
PM me if you like
Originally Posted by Tino
WTF
mrgil
Thanks all. I have no problem reading long winded logical replies... especially when they help. If only the stealership could be this helpful! Come to find out, the rim is bad... and expensive too. Somebody lobby congress to give us military guys a well deserved raise. As my uncle states in www.askuncleralph.com (he's the dear abbey of trailer trash), a bent rim is good for using as a flower pot or to hold up the old broke down pick up in the front yard. Guess what my next house hold upgrade will be!
John
John
