You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Will Fix-A-Flat damage tire pressure sensors (tires are not run-flats)
I'm running Continental ContiExtreme tires on my 01 coupe and am wondering if I did get a flat and added a can of Fix-A-Flat to get me home, would it ruin the tire pressure sensor? If so, how much are those to replace compared to a $300 tow-truck?
Go to the Tire Rack web site and look up the Continental Tire ContiComfortKit...they say it will not damage the sensors.
Everything that I have read about the "Fix-A-Flat" brand of tire sealant here on the forum says that it will get you home, but you will likely need new sensors when you are done. I am curious about this Conti kit. I've seen it on the tire rack and it says that it will not harm the sensors. I'm certainly not willing to try it as I have a '97 and the more expensive of the sensors.
Paul
Thats right.....do a search and you'll pick up some info, but bottom line, sensors are shot after using.....
Get the Autoclub PLUS card. I had upgraded my 5-mile tow to 80 miles free towing. It is worth the money the first time you get stranded and need a flatbed.
Location: ...Southampton, PA I love you & miss you Linda
Quote:
Originally Posted by We Gone
Yes..
Just carry a plug kit and a small compressor. When you get to your destination have the tire patched from the inside.
This is what I have done PLUS I carried a can of fix a flat. You never know the circumstance you may end up in and it may very well be worth it to use the fix a flat and replace the sensor in some cases.
Also, the fix a flat will not destroy the sensor, just gunk it up to the point where you will have to get in there and clean it up thoroughly.
You'd have to go in there anyway to repair the tire later anyway......
Yes it will most likely clog the sensor. You may be able to clean it out. There was a post here about that somewhere. I carry a new unused sensor along with my AAA card, cell, compressor, plug kit, tools, and some other stuff. After saying all that, I am looking to find ZO6 (C5) size runflats. Tired of chancing a flat or blowout...
I can't imagine how short term (less than 24 hours) use of fix-a-flat could totally ruin the sensor.
Seems once to a repair facility, take the sensor off the rim, R&R the stem, and blow some solvent through it, then a lot of air, repeat a few times, patch the tire, re-install the sensor, and be on your way.
I'm game enough to try that ANYDAY before I lay crouched on the side of some interstate with idiots zinging past me at 80 MPH+ or on some patch of crap road somewhere laying on my back wiggling around trying first trying to find the dang hole, then trying to plug it.
Way to much effort especially in adverse conditions (which always seems to be the case -- When have you had a 'convenient' flat tire incident)
The 01 and newer sensors cost a whopping $30 or so. In the event of a flat, that cost will seem pretty trivial.
A non-functioning sensor won't ever render your car disabled either....it's something (if it even does go bad) that you can fix at your convenience.
I carry a plug kit, small scissors jack, tools, and a small air compressor in the car, mostly just on long trips. Otherwise, around town, a can of fixaflat is all that's in the car.
If you also have an RV, Good Sams will tow you as far as required for no extra charge, Cost is about 100 dollars a year and covers all RVs,
cars and trucks in family. Darn, not horse trailers!
