[Z06] drilled/slotted
Old 11-15-2005, 03:28 PM
Z06_ownsu
Z06_ownsu's Avatar
Default drilled/slotted
I just bought a set of Gm drilled/slotted rotors for my 04 z06. Is there a write up for installation??? if any1 knows plz link
thank you
Old 11-15-2005, 04:05 PM
LTC Z06
Get Some!
Support Corvetteforum!
LTC Z06's Avatar
Two bolts hold the caliper brackets on, remove them, slide of caliper and bracket, change rotors, reverse. Go to the FAQ to find the torque specs. Some type of impact wrench would be nice to remove those two bolts.
Old 11-15-2005, 05:44 PM
UstaB-GS549
UstaB-GS549's Avatar
You need 21mm socket and 18" breaker bar for bolts. Turn wheels full lock to get torque wrench and good leverage. 125 ft-lb.
I push pads back with a heel bar and remove calipers first. It's a 15mm bolt and you need a 16-18mm (can't remember) to hold flats on pin after you break bolt loose.
I think you are supposed to use Loctite 271 Red on bolts or get new ones, but I never do.
Old 11-15-2005, 07:15 PM
RandyVettes
Life's Short. Drive Hard.
RandyVettes's Avatar
Cruise-In VII Veteran
St. Jude '03-'04-'05-'06-'07-'09
The ones from GM are not zinc washed. You will have rusty holes, hats, and vanes within 2 days of install. Take the time to either paint them or clear them.
Old 11-16-2005, 12:25 AM
C5 Z16
C5 Z16's Avatar
Default Rotors
http://dana60.com/rickko/corvette/rotor-rr.html
Forum member rickko did this write up that I found helpful. He used hi temp clear others have used hi temp aluminum color.
Jeff
Old 11-16-2005, 10:25 AM
Z06_ownsu
Z06_ownsu's Avatar
so basicly spray a clear on the rotors before installation????. btw that link is just a pic of 4 boxes.
Old 11-16-2005, 11:41 AM
RandyVettes
Don't coat the surface where the pad will ride but yes, coat or paint the rest. Black, Silver, Clear, whatever. Use something Hi-Temp.
Old 11-16-2005, 12:22 PM
Z06 Tom
Z06 Tom's Avatar
You can also use rotor hat covers, that's what I did with my "Dura-Stops." Mine are powder coated red to match the calipers. Painting would be cheaper though...
Old 11-16-2005, 02:20 PM
chrisj
chrisj's Avatar
St. Jude Donor '12
Here are some links I bookmarked a while back on this topic.
http://forums.corvetteforum.com/show...2&forum_id=103
http://forums.corvetteforum.com/show...0&forum_id=103
http://forums.corvetteforum.com/show...7&forum_id=103
(the link that probably went with the picture posted above)
http://www.z06vette.com/forums/showthread.php?t=79451
(not sure if it's ok to post a link offsite - remove if necessary)
Good luck!
chris
Old 11-16-2005, 03:53 PM
LTC Z06
Get Some!
LTC Z06's Avatar
He won't need to remove the calipers from the bracket.
Old 11-16-2005, 03:54 PM
LTC Z06
Get Some!
LTC Z06's Avatar
Good luck!
chris
This is what I need, when y'all collect this kind of info let me know and I'll add it to the FAQ.
Old 11-16-2005, 04:01 PM
LTC Z06
Get Some!
LTC Z06's Avatar
See post #45
To drilled/slotted
Quick Reply: [Z06] drilled/slotted
