does anyone use 2 pairs of ramps
Originally Posted by jacks996
How are you going to get the rear ramps under the car?
Cruise-In VIII Veteran
I've done it jacking rears up first with chocks against front wheels then jacked fronts and slid ramps under fronts. This way the rear brakes(and in gear) hold the car from moving forward when you jack the front. Use jackstands for safety.
St. Jude Donor '03-'05-'06-'07
front end and put it on ramps or stands. Then center lift the rear end and
put the other set of ramps in place. I use this technique to change the oil.
Originally Posted by navy99vert
Drive on the front .Than jack up the back slide the ramp under to tire.
Originally Posted by Vetteran
Assuming you have a pump handle hydraulic jack its simple. Center lift the
Received 1,680 Likes
No, I can't get a jack under the rear end with the front up on jack stands. When I change the oil, I will just jack up the front, pull the plug and set the car down on the drain pan for 15 or 20 minutes. Then jack it back up and replace the filter and put the drain plug back on.
When the car was at stock height, I would pull the front up on ramps and use the jack to raise the rear then put it on jack stands for the oil change.
Received 19,390 Likes
'20-'21-'22-'23-'24
I don't use two sets of ramps, but its not a bad idea.
