HELP – brand new CCW 505a valve stem leaking!! – please advise
Can the valve stem (of the air pressure sensor) be tightened only from the outside of the wheel or does the tire have to be dismounted and the valve stem tightened from both sides of the wheel?
I was polishing (mothers billit polish) my new wheels before bolting them on when I checked air pressure. Here it is: 28, 24, 16 and ZERO. I aired all four to 30, and monitored for a few hours. One is really leaking fast and a little soapy water showed the valve stem (on one of the wheels) to be the culprit.
I really don’t want to have to ship this wheel back to John at CCW and wait another 1-2 weeks because I will not be a happy camper!
Just curious from you 505a owners: , did your tires have ~30psi when they arrived shipped?
Thanks guys.
Thanks guys.
Received 3,812 Likes
St. Jude Donor '03-'04
Yes
Cruise-In VI Veteran
St. Jude Donor '05
I think mine were actually a little more than 30psi. Mayve 32-33psi. I have never had any problems with leaking air. I suggest you work it out with John. When I received my first set of 505as, they were not balanced properly and there was a shimmy in the steering wheel. CCW was very helpful and they sent me a new set. They will make it right, but it takes time. You should get a perfect set for the amount of money you paid.
If it is leaking from the end of the stem you can go to any tire shop, they will have a tool to tighten the stem free of charge, it is real easy, takes about two seconds. If it is leaking around the base there should be a nut holding it in place just tighten it with a wrench. I had that trouble after I had new tires installed, not a big problem. If tightening ether place doesn't work, then it might take sending them back. Good luck with it.
Had my sensors installed on my 505A's at a Discount Tire. Any large chain should be able to fix what ever the problem is. Much easier than shipping the tire back.
Cruise-In VII Veteran
people, evil-twin gave the answer-yes; grab a wrench and tighten the nut on the stem, if that doesn't work replace the oring(tire will be rem'd for that); no special tool, no need to have someone else fix it; edit--the $$fmtin the posted below also has a good point of the schraeder valve being the prob
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I had the same problem with my Iforged wheels. I fixed it myself by snugging up the internal portion of the valve stem. I used a tire gage that had the tool on the other side of the gage. EZ! Use soapy water to observe results.
Thanks everyone. I tightened the nut on the stem slowly but the bubbles did not even slow down (soapy water) where the stem meets the wheel. I not sure how much torque to tighten. I don't want to crack the sensor. I just checked my other three wheels and one of my fronts is leaking as well. That's 2 out of 4.
Received 5,237 Likes
Sensors may already be damaged.
Good luck.
Good luck.
sorry - this is my last post and I'm done with this thread. I just soaped down all wheels again and 3 out of 4 are leaking where the stem meets the wheel. I have to say I'm surprised these were not tightened better before they were shipped out.
Received 19,385 Likes
'20-'21-'22-'23-'24
Good luck getting the leaks fixed. Hope it all works out for you and you don't have to send the wheels back.
Just FYI - All has been taken care of. As has been stated before, John at CCW ALWAYS takes care of his customers. Excellent customer service!!
