Chevy dealer wants $900.00 to fix fuel gauge...
Hi Everyone....My fuel guage on my 99 vette often goes to zero and then sometimes will return to where it should be...I took it to the chevy dealer and they tell me it's a bad modual sending unit issue and the part is around $700.00 and about 200. for labor. Has anyone else had this problem and what do you all think of the costs????? Thanks, Dennis
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
what are they going to do...?
...follow you around with Techron...
...loaded StuzVette up with Chevron and problem went away....
Maybe you can fix it for free....
Free Techron at AutoZone with rebate..Check it out...
http://www.autozone.com/images/in_our_stores/1_8i.pdf
Techron didn't fix mine. I made a post the other day about this same thing. I have the same issue. The overwhelming response was to go through 2 complete tanks of CHEVRON gas. I advise doing this. I haven't emptied my current tank of "bad" gas, but when I do, I'm going to try my first of 2 tanks of Chevron gas to cure this issue.
Originally Posted by mlupone
okay, what the heck does techron have to do with a fuel sending units guys?!?!?
http://forums.corvetteforum.com/show...ge&forum_id=49
Location: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Just a note Techron will not solve then problem all the time.
I have the problem and GM has already replaced my senders. I have only used Chevron 94 with Techron since the replacement of the senders and have also used bottles of techron.
As I said before I still have the problem!!!!!
i use ammoco ultimate and dont have a problem
if ofr some reason i have to get another brand itll pop up on me within a few days
ammocoo is BP
and theres only 1 bp station ive found that works well for me
maybe it superstision but as long as i go to jsut htis station i am fine
ammocoo is BP
1 Post
I had the same problem, it fixed itself after running Chevron fuel
only, nothing else. It took about eight tanks for the problem to go away. I guess this doesn't work for everyone but if you top off your tank when this happens or keep an eye on miles traveled, you might
save some $$$$$$ in the long run. Worth a try in my opinion
yea yea...but we like to sound like we have the absolute answer...
...we sound so smart
...actually... it is a good first thing to try
[QUOTE=03ZnChicago]
thanks
Jeeze, gotta love Stuart!
thanks
St. Jude Donor '03
My suggestion is Chevron and only Chevron. If you can't get Chevron then get techron by the bottle. I've had the problem several times and it's always while I'm on vacation and can't find Chevron. As soon as I go back to Chevron it clears up. Just my .02!
1 Post
