CAN'T DECIDE!!! Run Flats or Non Run Flats?
Originally Posted by iteachflyin
Gotta admit that I haven't driven a Vette without GY OEM runflats. But I've driven a hell of a lot of cars in my day, as have you all, and these things are not that noisy. I personally believe it's a bunch of bunk about all the runflat noise. If you are experiencing too much noise, your runflats are over inflated. I like the safety of having 'em, even though I supplement my sense of well-beingt with AAA.
GY runflats are very loud.
Non runflats are MUCH quieter.
You should not comment if you have not drove a non runflat car.
I ditched the runflats on both my C5's post haste. You'll save yourself mucho bucks and be pleased with performance/noise reduction. I don't concern myself one iota with the possibility of a flat. If it happens, ain't no big thang (to me). I've never, ever had a flat tire. If I had one in the 'vette, I'd call a flatbed.
I will caution you, though, that it would be prudent to have the sensors reinstalled if you go with non-runflats. Not only for the monitoring but the DIC messages you'll avoid that would drive ya absolutely nuts.
Tires
I recently installed the Nitto 555s. They make a world of difference. Not just quieter, but the ride is so much smoother. which really helps with my lowered car. I carry a plug kit, compressor, AAA card and cell phone. I used the plug kit on the original runflats. It's a good idea to practice on an old tire. I added an Xacto knife. a small drill bit and long-nose pliers to the kit. I'll neve go back to runflats.
I've heard rumors that a spare tire off of a GTO will fit. I would love to ditch the runflats, and have one of these available to throw in the trunk for long trips!!
Location: Woodlake,The hill is without the king, California
1 Post
St. Jude Donor '08
Originally Posted by Crispyc21
It really depends on how you would feel about the possibility of having to repair your tire on some dark road somewhere. Is the smoother ride and less noise worth it.
I got rid of my run-flats. The ride was like another car. So nice!! But be prepared...have a patch kit, compressor, flashlight, and jack.
Just last weekend I was leaving the mall and picked up what looked like a hollow nail. I didn't have anything to fix it. I limped back to the mall which had a sears auto center...which was closed. After calling a friend and going to two different stores to find all the stuff, two hours later I was all patched and back on my feet...well tires.
Overall: The ride is smoother and quite without run-flats...just be prepared!!
Originally Posted by BlownV6
I'm going with Nitto 555's when i need to replace my runflats. Only 600 dollars for all 4
Received 19,414 Likes
'20-'21-'22-'23-'24
With the runflats, you'll probably give up some ride and handling advantages, but you won't be stuck on the side of the road in the middle of nowhere with a flat tire. Really comes down to your comfort level having to deal with a flat. If you buy a cheap repair kit, it may be a moot point going with the non-runflats.
Nail in side of run flat repair
Originally Posted by IM QUIKR
I just installed a set of Nitto 555's and what a difference in noise, bump steer and traction. And I don't have to worry about the cost. I can afford two full sets of Nittos for the same price of Pilot run flats. FYI, If you pick up a nail near the side wall of a run-flat they can not be repaired. That gets expensive as I found out the hard way. Get a pump and plug kit and save yourself some cash.
On our 2002 vert, we had a nail in the side and the Goodyear store removed the tire and placed an inside patch on it.
The wanted to sell me a new tire instead.
1 year later, it still held.
Maybe I was lucky.
Originally Posted by Postergeist
I If it happens, ain't no big thang (to me). I've never, ever had a flat tire. If I had one in the 'vette, I'd call a flatbed.
I went with the Goodyear Eagle F1 GS-D3 non-runflat tires when my OEMs wore out. I'll never go back. These are by far the best tires I've ever used and the road feel, ride, and handling are far superior to the runflats. Remember, ALL Z06s do NOT have runflats. Just NEVER, NEVER use tire goo (tire repair goo from a can) as it will DESTROY your TPS and more than likely require you to purchase a new tire.
I keep a plug kit and small 12 volt air pump in the trunk in case of punctures. Chances are that you will not experience an explosive decompression of a tire. Much more likely a very slow leak due to a puncture with the foreign object still in the tire. Your TPS will warn you of this. All you really need to do is reinflate the tire and drive until you get to a place to get the tire patched. If you are a DIYer, pick up a tire plug kit from Pep Boys or Advanced Auto for a few dollars and you can fix your own punctures. You don't even need to take the wheel off the car (but you may need to jack the car up depending on location of the puncture).
I've never had to repair the Vette's tires, but my wife's old Miata had 3 plugs in her set of Yokohamas and my RX-8 already has a plug in the front tire. The kit has paid for itself so many times over......
#33
Lepus-temperamentalus
I can understand why some would want to go to a non-runflat and the arguements here are impressive...but they aren't for me.
I imagine myself out on some dark, lonely road in the pouring down rain, me trying to get the jack under the car with mud up to the sills, unable to find the nail.
That brief flash is enough for me to say, "No way". I'll put up with the extra noise from runflats. Just crank up the stereo louder.
#35
NON RUN-FLAT repair kit - jack, plug kit, compressor, etc.
RUN-FLAT repair kit - hotel reservation - no one out in the "boonies" will fix, repair, replace a run-flat. Be prepared for a long stay!
#36
I don't blame you.
#37
I changed to 19x10fr and 19x11 rears with BF Goodrich TA KDW2s, non run flat. Believe it or not, they handle much better and look damn good! They also take bumps much better. They have pressure sensors so I do get an early warning. Based on the ride, it will take a lot for me to revert back to runflats!
#39
Originally Posted by mcburner
I'm torn. I need some new rubber soon and I've heard people (mostly here on CF) say change to non run flats, some say, "no way, got to have the run flats". I've pretty much decided on the Michelin Pilot Sport's but I need some good advice on Run flats or not. Give me your opinions please. Thanks, Mike.
I spent $1300.00 for new Good Year EMT's and notice less noise and far more grip than the worn OEM's.
#40
The GY EMTs are pretty noisy and that's what irritated me the most about them. After the first set I went with Firestone Firehawks and have been very pleased with their quietness and ability in the rain. Now I'm on my fourth set.
For my daily driver I'll stay with my Firestones.
