4 hours labor to change rotors ands pads?
Dealer quoted me 4 hours to replace rotors and pads. Is this reasonable? Thanks!
Originally Posted by ecudooberhead
All 4? Yeah, I'd say so. Why not DIY- its not hard
Originally Posted by Lestat712
Put up on lift
Take off tires, brackets/pads/rotors
Put on new pads/rotors
Bleed brakes
Put on tires
Take off lift
Test drive
Did I leave anything out?
Bleed brakes
Put on tires
Take off lift
Test drive
St. Jude Donor '05
Originally Posted by pcfred
If you have the stealer do it watch them and time them (deduct time for breaks, etc.) then when it's done if they only took 2 hours tell them that's what you should pay for and not the quoted 4 hours, if they insist you pay for 4 le5t them know you're gonna take the matter up with Corporate and the BBB.
I was charged 5 hours for replacing all 4 rotors, pads, AND brake lines (stainless steel, required flushing the brakes). They had two guys working on it and took just under 3 hours. Total with supplies (less tax) was about $480.
This was at a Milwaukee area Chevy Dealer.
UT-Driven
It did not take me that long to do mine. I would say 2 hrs with a jack and some jackstands.
No need to bleed brakes if only changing pads. Make sure you torque the bolts to spec. I had heard of caliper bolts letting go while driving -a little loctite helps.
4 hours?! you have got to be kidding me, I use to be a ford technician, but if you cant do all 4 rotors and pads (and this includes turning the rotors as you work) in 45 minutes, you must have one arm.
I did my front rotors/pads in 20 minutes and I turned the rotors while doing it.
UT-Driven
Put up on lift
Bleed brakes
Put on tires
Take off lift
Test drive
Bleed brakes
Put on tires
Take off lift
Test drive
I used floor jack and jack stands. Don't forget the "red loctite" on the bracket bolts and the "blue" on caliper bolts.
Use speedbleeders to bleed the system. May as well bleed out all the old brake fluid and refill with new dot 3 or dot 4 brake fluid.
It may take you a little longer than 4 hours, BUT you will save a bunch of $$. may as well go drilled and slotted rotors
That is my $0.02
