Here's why you change your own oil.
Lepus-temperamentalus
Getting ready for a trip to Memphis so I thought I'd give it a once over and and oil change.
So I put it up on stands and was under it changing the oil. I'd unplugged the oil drain and was waiting for it to finish draining. While I was down there, I was just looking around and....now that looks weird. Why is that piece of metal hanging down? Because there's a hole in one end with nothing in it, that's why. THAT'S MY FREAKING LEAF SPRING CLAMP!!!
Yep, one clamp was just about off altogether. The bolt holding it on could be turned by hand and the other clamp was just about as bad.
Gotta go to the Chevy store tomorrow for one little bolt, but no big deal.
Wonder if the guys at "Jiffy Lube" would've noticed that?
That's the way I feel!! I want to SEE what's under there! And, I don't want some "ding-dong" working on my car. I want to KNOW what's actually going into it, and not rely on what someone says they're putting in it.
Not only would the characters at "Quickie Lube" not have noticed it, they might even have CAUSED it !
My buddy took his new van in once for an oil change. Well, their "ten-point" check sshowed the brake fluid was low.....so they topped it off..... with
engine oil.
A few days later my pal's wife went sailing thru a busy intersection with no brakes, due to the petroleum-based engine oil eating the rubber seals in the brake system...... She didn't hit anything, but it took him over a year to squeeze the $900 buck repair bill out of them.
engine oil.
When I put on my bullets, one sway bar link had the bolts backed out and one clip was gone! So now it's fixed, I from time to time look underneath for this reason,...........
St. Jude Donor '05
Originally Posted by pcfred
Did you use the jack pads? Are they really necessary? What if you had taken it to Jiffy Lube would they use some sort of pads?
Jiffy lube has a pit... the "ding dong" (I didn't say that) in under the car in the pit so they don't have to jack the car up.... therefore no need for jacking pucks!
Even if you don't change the oil yourself you should still get under there from time to time....
Received 19,307 Likes
'20-'21-'22-'23-'24
Good catch. You're right about the benefits of changing your own oil - I give the underside of my car a good look over at each oil change.
Good Catch Jack. a big part of changing your own oil is to take the time to look and inspect the underside of your car. Look UP into the radiator and remove any debris and crap that may have gotten up there.
i see guys with plastic bags draging from under their vettes all the time. too lazy to get down and LOOK I guess.
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I'm getting more comfortable jacking up my car and putting it up on stands every time I do it, so this is one thing I may have to start doing on the regular. I know I need to clean the debris out of my radiator.
I still haven't gotten the ***** to lay under the car yet, as all the work I've had to do has been on the brakes, but it's something I'm going to have to do, especially since you found loose parts hanging down!
BTW, Stock Man, your avatar inspired my photography after my brake upgrade! See sig...
I know what u mean. I try to miss those pesky plastic bags flying around the road. If I can't avoid one I always look back to see if I picked one up. I cannot stand to be driving around with a plastic bag hanging off my ride. It reminds me of somebody walking out of a restroom unaware that tissue is stuck to the bottom of their shoe. It just looks retarded.
DISCLAIMER: No offense to the mentally challenged.
They also let me go downstairs into the pit area to watch and inspect.
Most chevy dealers dont want you near the car when they are working on it.
BTW, The first time Jiffy Lube changed my oil (my very first oil change) they actually caught a Tranny leak and notified me of it. I then took it into the dealer the next day.
Originally Posted by MARK's_C5TT
Its good that you caught that with your own eye. But with the exception of the most recent oil change, I actually go to a Jiffy Lube near my house who treat me well. Its the dealer that you have to watch out for. I bring my own Mobil 1 synthetic to JLube and they charge me like $26 to do the change which includes the filter.
I'm lucky. My dealer has two techs that are terrific and very experienced with Corvettes. I trust them and they have never let me down. When you find a dealer you can trust, stay with them even if it cost you a little extra.
