Windseld Heads up display
Old 04-14-2005, 07:41 PM
2079's Avatar
Default Windseld Heads up display
I just had my windshield repaired " a rock ". I was informed that if I was to replace the windshield with heads up display it was almost double the cost.
I remember reading a thread were you could install heads up on your car as a kit although you did not have to change the regular windshield.
QUESTION if I ever do have to replace the windshield can I just use a regular windshield?
Old 04-14-2005, 07:49 PM
X-ZZ4
X-ZZ4's Avatar
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I stand corrected......I just looked it up on GMPartsDirect......
No HUD = $271.42
HUD = $794.03
Old 04-14-2005, 08:11 PM
Sorny
Sorny's Avatar
Do you carry full coverage insurance?
If not, you should. No cost glass is a VERY desirable insurance option (should be part of your comprehensive coverage) on the C5...
Sorny
Old 04-14-2005, 08:19 PM
michach1
michach1's Avatar
I installed the HUD in my car without changing the stock windshield. No problems seeing the display at all. Save the money.
Old 04-14-2005, 08:24 PM
rac03
rac03's Avatar
someone must know what the difference between the two windshields is. I would be interested if anyone knows.
Old 04-14-2005, 08:27 PM
VetteDawg
Support Corvetteforum!
VetteDawg's Avatar
I also added HUD and it looks just fine with my non HUD windshield.
Old 04-14-2005, 08:37 PM
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
The HUD is suppose to be more reflective. If you look at them side by side, esp. in the right light you can tell a slight difference. If the $$$ is coming out of your pocket I think you'll be perfectly happy with a regular windshield. If the insurance company is paying, make them buy you the HUD one
Old 04-14-2005, 08:47 PM
Red86Cfour
Red86Cfour's Avatar
My C5 had the windshield replaced before I got it. I strongly suspect that non-hud glass was installed. No complaints.
Old 04-14-2005, 09:07 PM
2079's Avatar
Many thanks for the repliies.
Bottom line , lots of money for very little difference. I will save my noney if I ever have to replace it and will buy a regular one.
Old 04-14-2005, 09:34 PM
RockyL32
RockyL32's Avatar
Location: If your not the lead dog the view never changes Boise, Id
I was told that the HUD winshield is slightly staggerd.....The wind shield is made up of two pieces of glass with a sheet of film in beetween to bond them (safety glass construction) to keep the HUD display sharp the safety film at the bottom is a little bit thiker at the bottom to align the reflection of the HUD thrue both sheets
Old 04-14-2005, 09:41 PM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
That's the way I would do it too.
Mike Mercury
Mike Mercury's Avatar
this is 100% correct. And that's all the difference there is supposed to be The uneven safety film is to reduce the "paralax" effect.
Old 04-14-2005, 10:15 PM
c5BlackBeauty
Corvette C5 Enthusiast
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
To Windseld Heads up display
Quick Reply: Windseld Heads up display
