How do you get the #@#@#$& air box off?
I got the new air filter today. Instructions say "just take the old air box off...remove the twobolts from the front bumper.......
How the @#$#@ do they come off? They don't have flat head screws. They don't have phillips... no allen head... WHAT TAKES THEM OFF????
Zooom
Zooom
Originally Posted by screw991le
Just pull, they are held on by rubber gromets.
Paul
Originally Posted by talon90
Just use a screw driver wrapped in a towel and pry them off. It is a rubber gommet on a post. Should be good to go.
Paul
Paul
St. Jude Donor '05
If you are talking about the 2 Bolts holding the Air Box itself to the front inside bumper; this is bolted on with 2 Torx screws T-30 Torx driver will work, however it will be a tight fit with the radiator shroud in the way, it would be better to have a 3/4" ratchet with T-30 torx attachment. The air intake screws (plastic) just pop out with a flathead screw driver as said in the previous posts, hope this helps
Received 19,292 Likes
'20-'21-'22-'23-'24
Hope you got the air box off the car.
That's what I did. Got a ratchet with extension and torx drive bit, and with a lot of patience and ripped up hands, from such a tight fit, finally got those bolts out.
Certainly would have been nice to know you could just pry them out of those grommets!
You guys are GREAT!!!
Not only do I get answers, I get pictures! Bottom line... The new air cleaner is on. Works well... couldn't have done it as easily as I did without You-all!
THANKS!
Zooom
THANKS!
Zooom
