Can we still say "Wrap your ass in fiberglass"?
1 Post
Can we still say "Wrap your *** in fiberglass"?
I had a buddy in high school who had an early 70's vintage Vette ( which routinely kicked my 1969 Mach 1's ***!) and he always wore a T shirt that had that slogan on it. He also had one that said " I'd rather be blown then injected" but that's another story!
I was wondering. What exactly are these C5's and C6's made of? Is it still glass or some sort of plastic/glass blend?
Obviously, I'm bored at the office today!
Received 19,286 Likes
'20-'21-'22-'23-'24
I think it is now called SMC (sheet molded compound, or something like that). Not sure if it is technically fiberglass, but it does seem to avoid a lot of the stress cracks that were inherent in fiberglass.
Yes! Or else I have to change my screenname.
Maybe Patches will chime in with that diagram again....
SMC = Sheet Molded Composite. What I don't know is if that is just the body structure as a whole or if it includes the outer panels (fenders, hood, doors, etc.)
Simply put, e-glass is fiberglass, and SMC uses e-glass so it's still fiberglass.
Received 1,674 Likes
Wrap your *** in composite?
mcm95403 (04-07-2020)
Originally Posted by The Kid
You can still call it "The Plastic Fantastic" if you want.
Originally Posted by jcharity
Wrap your *** in composite!
Its STILL just fiberglass but they try to hide the fact by calling it by the more technically correct name that implies the process of fabrication . Lotus did a lot of work in the late 70s on advanced methods of mass producing higher quality auto body panels. Later on, as aerospace /aircraft techniques of pre-impregnated composite sheets and pressure autoclaves trickeled down to the masses, we began to see presure forming and high heat autoclave curing in more and more low tech applications...like mass produced cars. The bottom line is that with pressure molding of pre-preg, the ratio of fiber to matrix can be better optimised than in chop spray [ the worst] or hand fabric/matt layup with resin roll-out [better than chop spray ] .
Most of our C5 is still just e-type glass fiber and some type of polyester resin, same materails as the old days. The flexible fascias are a urethane family, and the clear top is, as mentioned above, just a generic 'Lexan' polycarbonate. Nothing too exotic in the Vette, but appropriatly durable and cost effective materials have been chosen to keep the cost down and performance up.
1 Post
St. Jude Donor '05
CI VI Veteran
It may still have the same materials but you sure don't repair it the same.... (Thank God)
Mark
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Mark
Mark
Mark
Mark
