What problems could I run into doing this???
I posted in tech but haven't seen any help there. I know this part of the forum is one of the most technically capable and informative and thought I'd try here. Hope it doesn't **** off the mods.
Here's my question:
I have Fikse FM/10's 18 x 9.5 front and 19 x 10.5 rear. I posted to trade the rear 19's for someone's 18's provided they were 10.5 wide at least. No one was interested. I then posted the whole set for sale and I guess being just after the holidays money is tight and I had a very hard time getting someone to give me $2k for them including wheels and tires and an extra set of 19 inch tires brand new. After thinking about it I don't really want to take that kind of a hit on a $4500 wheel and tire package. I paid around $3k and that's still too big of a hit for me and I love the rims.
I was wondering what problems you could forsee if I ran the 18's on the back and the 19's on the front. The reason being is that I have 512 rwhp and 497 rwtq, of which I have 450 at the wheels at 2200 rpms and I just can't get traction on street tires. I want to switch to a drag radial like the Nitto or BFG but they only come as large as 18 inch.
Am I asking for trouble? What can happen?
Thanks for your input.
MM
Here's my question:
MM
Here's my question:
MM
Here's my question:
MM
You may run into abs issues running a 19 front and 18 rear. I would say get a wider, taller 18" for the rear. I would try to sell the entire set again. Tax season is almost hear.
as long as you keep the same rolling radious then in theory it will work! but i wouldn't do it. better off going for the same dia. wheals front and back. having saod that a lot of manufactures run larger rear wheals than fronts.
thanks Chris.
thanks Chris.
Supporting Vendor
1 Post
Well, other than it looking a bit funny, you will have to get a taller tire in the back. The C5 traction control system depends on your overall front diameter being less than your overall rear diameter. I don't know specifically what, but I have heard that really weird things will happen if the front is within one inch of the back.
And thanks to all you very very much for the information. While I do know it might look funny I thought that I'd try it...I would think only one inch would not be that noticeable but I'll see....at least until I cen get a reasonable amount for them. I'm thinking tax refund time next month or March. My main concern though was handling characteristics, and and emminent danger doing this and it doesn't seem like it from what everyone has said.
Please keep the advice coming.
THX!
MM
You should be able to contact Fikse....you can Probably send them your 19" wheels and have them made into 18's. My Brother is in the process of doing this with his HRE's.
You can then run 18's all around and use drag radials. you compromise a little look, but what good is a 500+ RWHP car if you can't use it? Chekc my Sig...get an idea of wht it looks like with 18's all around.
Supporting Vendor
1 Post
diynoob....I thought those issues were had with Active Handling which I don't have. I shut traction control off all the time because it's no help to me so wouldn't I be OK.
Well, I thought TC looked at front wheel speed vs. rear wheel speed to understand when the wheels are slipping. So I would just validate that it does or does not before moving forward with your thought of swapping the tires around. A shorter tire in the back will make it 'appear' that the wheel is slipping since it will be moving faster than the front.
3x...I seriously tried...all I wanted was the person to pay shipping both ways to get the upgrade but after a month no one bit. If you know anyone...please let me know. THX!
I will definitely double check.
I don't think I tried the For Trade post on Z06 forum but I did put the For Sale post there and here too.
They are FM/10's in Technipolish finish....19 inches tall and 10.5 wide. Light curb scratches on right side...like a couple inches long but otherwise both in beautiful shape. No sensors.
I appreciate you looking out for me and trying to generate interest.
THX!
MM
THX!
MM
