A&A Procharger kit vs Stock ATI kit, my little writeup for anyone doing research
I've done both and heres a list of the pros and cons that I remember. This is my opinion and based on my experiences.
Stock ATI Kit Pros:
-Not too hard of an install
-More of a factory fit
-Generally ran good
-Very easy to return to stock
Stock ATI Kit Cons:
-Overheating problems (depends)
-Belt slip problems (depends)
-Makes a little less hp than A&A kit (no other mods)
-Not very efficient design
-Very difficult to sell
-Not easily upgradeable (power)
-Doesn't look as good under the hood
A&A kit Pros:
-More hp (no other mods)
-More efficient design
-Boost comes on quicker
-Much better design (performance)
-Much easier to sell
-Easily upgradeable (power)
-Looks awesome under the hood
A&A kit Cons:
-Much harder install
-Lots of drilling, cutting, and relocating
-Much more difficult to return to stock
I have done research, talk to people with different kits, and like I said, I myself had done both kits. When I did the stock ATI kit, the install was pretty straightforward, and fairly easy. My stock ATI kit ran perfectly fine for me, but it was quite obvious by the design that upgrading in power was going to be a problem. I'm sure there would be belt slip issues if I used a smaller pulley for more boost. There would have to be quite a few things changed to make serious power. The bracket and pulley setup is just not really any good. As long as I was cool with 465rwhp at 7lbs, that kit was fine for me. I had no cooling issues whatsoever. The main thing that wasn't good was the inefficient design and that in fact lowers performance. The stock ATI kit is much easier to return to stock, since there minimal changes and relocations, however it is very difficult to sell because of the better A&A kit. Overheating issues seem to be because of the single fan setup and inefficient airflow, but also seem to be in really hot climates. I don't think theres too much belt slip problems when keeping it around 7lbs, but if you up the boost, thats when problems seem to come up.
When I got my A&A kit, it looked much simpler and looked like a breeze to install. I was wrong. I don't know why, but it fought me every step of the way. It was like 10x harder. It just seemed like every little thing that had to be done, required changing stuff, cutting, drilling, trimming, bending, ect. Returning this to stock would not be fun or easy, but selling the kit would not be a problem. The main difference that stood out was how much more efficient the kit looked. Theres hardley any plumbing, one big intercooler, and one badazz bracket setup. Upgrading power, like running a smaller pulley for more boost doesn't seem to be a problem, since the bracket and pulleys are so well designed, I don't think it would slip that easy. Also, the blower intake setup is 100% better as well. I better not even try to explain what the air had to go through on the stock ATI kit to get to the blower, you'd never understand what I'm describing!! Anyway, after getting everything installed, and just taking a step back and looking at it, I realized it was worth the PITA installation. It looks great. I don't really have any performance results yet from the change, but I will in a week or two. Upon driving, I noticed the boost comes on much quicker and it feels much more responsive.
The reason I sold my stock ATI kit is because I was going to do a twin turbo setup, but I realized I didn't quite have the money for that yet. I can't be without forced induction for long, so I decided to pick up the A&A kit for the time being. I'll probably do the twin turbo project sometime later on in the year.
My verdict: For me, I wouldn't get the stock ATI kit again. I'd rather suck it up through the installation and have the A&A kit just because of the performance design and looks. I'd say all around the A&A kit is much better designed, Andy did a good job with it.
If anyone has any questions about a specific thing I said, or wants me to elaborate or explain, just let me know.
Stock ATI Kit Pros:
-Generally ran good
Stock ATI Kit Cons:
A&A kit Pros:
A&A kit Cons:
1 Post
Congrates I had thought of going to A&A kit but I think I will wait to see some of TT systems that are coming out. I have the stock ATI system now running at 7PSI and it will have to do until I decide what route to take. Even with my stock system, I have a hard time keeping my car from fish tailing under WOT. With that said, I still want more horses and it will be one of the TT or A&A kit but with the F1 instead.
Awesome write up..
Thanks for taking the time. Since you have seen both kits take a look at mine. Tell me if you can tell if my kit is ATI or an aftermarket setup. I know some of the pieces are ONE off from MTI. Its an 8 Rib setup which I know and my intercoolers are prototype 4.5inchs thick. Other than that I dont know what I am getting...
Heres a picture:
You can also look in my sig to see more of an installed setup.
Jon
Heres a picture:
Jon
Keith
Nice bracket and head unit, xceler8. but, those twin intercoolers and all the associated piping can't possibly work as well as the A&A single intercooler and short, direct plumbing. it would be cool to have Andy's intercooler and plumbing with your head and bracket. that would make a killer blower even better.
I'll be curious to see how much power BlownFRC picks up over his old set-up.
Jon
Location: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
1 Post
ATI air inlet...
[QUOTE=BlownFRC
Also, the blower intake setup is 100% better as well. I better not even try to explain what the air had to go through on the stock ATI kit to get to the blower, you'd never understand what I'm describing!! UNQUOTE)
I'm glad you mentioned this...I don't remember seeing anyone address this before on the Forum.
When Andy put his upgraded kit on my C5, I stood there looking at the old ATI air inlet setup and was is total disbelief! The geometry of it is appalling-it is one big sharp right angle bend with a big hulk of sheet metal immediately facing the blower inlet! I'm sure that only the most ambitious and dexterous of air molecules could negotiate through that skinny inlet configuration!
And then there's the air cleaner, teeny, tiny! I'm sure it must be a special open porous weave (that may let a lot of larger particles through), otherwise you would have to clean it about every 500 miles or immediately after a couple hundred feet on a dirt road.
Anyway, as soon as Andys' setup was on my car, my cars asthmatic wheezing and pitiful sucking sounds stopped and a couple more lbs. of boost miraculously appeared!
Roy
Roy
I'm very interested in hearing what has to be modified to install the A&A kit. I'm thinking about purchasing it this summer or fall and want to make sure it isn't something I'll regret doing. TIA
So since you switched from stock to A&A what was your HP gain given the same boost level. Also what type of unit were you using so we have something to base it on. This way if I want to goto a SIC later I can get an idea of how much extra power I can pick up.
Jon
Jon
Platinum Supporting Vendor
I'll throw my 2 cents worth in here. The intake duct over the radiator can be areal PITA to install, but that's where a lot of the efficiency is gained. Look how much an aftermarket intake does for a naturally aspirated motor. Opening up the inlet does the same for a forced induction setup. More air into the blower- more air into the motor.
When we do them at my shop, it actually takes less time than the standard setup for us to install. Although, I'll be the first to admit that the air inlet and top radiator support can be frustrating. I'm working on having an inlet duct fabricated with a large offset in it so that the upper support will not need to be modified so much. It will still need to be shortened but the top won't have to be trimmed out for clearance. It will be functioanlly the same, just easier to install.
As for putting it back to stock: that's really not a big deal. A new skid bar and and upper support are all that is needed. They bolt right in and are fairly cheap.
As always, I'm always open for suggestions.
I've had a few requests for a clear shroud so that you can see the intercooler and filter etc. So I'll make a few that way for those that want them. Different colors for tubing and couplers are always available too. all you have to do is ask. Any other suggestions, requests?
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
Originally Posted by XCELER8
Awesome write up..
Heres a picture:
Jon
Heres a picture:
Jon
Roy
Roy
I used to have Andy's kit. I only had two problems with it. I still had belt slip...but I had belt slip with previous bracket also. And the couplers. I had couplers blow off the head unit all the time and off the MAF. I changed all the couplers to transition hoses and had no more problems. Ofcourse my kit was closer to when he started making the kit...it might have changed now.
I bought Andy's kit (P1) last month, and had ADS in Chandler AZ do the install and tune. The install even for the experts turned out to be a longer job than they expected. Getting the radiator just right and the silicone tubing aligned was the slowest part. They had done the ATI install, but hadn't done one of Andy's kits.
Good #'s so far.....all stock 2002 LS1 except for aftermarket exhaust....573 FWHP/502 FWTQ on a Mustang Dyno. 11.8 to 12 for the A/F. Still have stock fuel pump, kept up 55 to 58 lbs. up to 6000 RPM. I got nearly 8# of boost at 6K. They still recommend a BAP or a Racetronix just to be safe. All I need now is an aftermarket clutch and big ole' tires...
Originally Posted by Scubanme
Thanks for taking the time to let us know about the realities of SC setup installation.
I agree. I read the A&A instructions before I purchased my ECS kit just to get a feel for what would be involved. By page two I realized that I would be in way over my head and decided to send my car to a 'tuner'.
Mark
Mark
