Who is Making Big HP With Stock Fuel pump?
I am am just Curious...I have the Stock pump, and am working on an upgrade, but Just interested to see who is doing what with a stock pump.
I currently have the stock pump, 42lb injectors and no boost a pump. With a Vortech intercooled set up. On the dyno the car is running 550-560 RWHP, only because it get REALLY lean on top. My HP Is shooting straight up still, but I don't want to cook the motor, and I know I'm pushing it now. How much does a boost a pump really help? The first thing I need to do is get the bigger injectors...my 42's are 100% at all times!
Lets get some input!!
I am looking at the MSD unit, because it is Boost adjustable, But I am not sure....Does my '02 Z06 have a return Line Set up or not? This unit requires that you have a fuel return line.
fuel return line
Originally Posted by loudsam
I'm pretty sure that I've read that fuel injected cars have a return fuel line. Maybe that's not what your talking about. I know when I started getting interested in engines again, after about 30 years since. I was surprised to find that there's a return fuel line to the tank on fuel injection! Not so, with a carb car.
Not all vettes have a return line on the fuel system. I think that they only did that on 97-98 fuel systems. I think after 99 the didnt put a return line on them.
there are no high hp cars with stock pumps responding because they are all busy installing new pistons. don't mess with a bap. go ahead and get the ractronix kit. the install isn't very difficult and you will be ahead of the game.
also a lean af ratio makes more power. if you are leaning out, you will be making more power. but you will be busy changing pistons too if you don't get more fuel and that af in check.
I kinda noticed that quite a few folks are switching over to the 97-98 fuel rail setup. Somethin u might want to look into. That and an aftermarket pump setup would probably be the best way to do it. I also don't know where you stand finacially though. I am not an FI guy, this is just what I noticed. I hope that others will chime in on my comments now as to help inform you with their experiances.
A BAP will work on any fuel injected car. They all have a return line of some sort. Even the '03-04 cars have one, it just happens to be in the tank.
97/98 has the regulator and return up front directly on the rail. This helps keep the pressure more consistent on the rail, since you don't have all the delays associated with having it 10ft back.
Originally Posted by QuickSilver2002
Yes, it has a return line. It just happens to be in the back right near the fuel sender instead of on the rail (the regulator is integrated into the fuel filter on 99-'02 cars). Just think of the ’02 fuel rail as being about 10 ft long with the regulator and return near the driver’s side rear wheel. .
So far I am leaning....
Racetronix
MSD boost a pump
50# injectors
Alky injection
Sound good for about 650RWHP?
I have a ractronix plug and play pump and harness system on my 2000 with 60lb mototrons and it supported my s/c 660 rwhp just fine.
Bill
St. Jude Donor '06
You know if you read around here you learn through other people. One thing I learned is you don't want to get too cheap when it comes to getting fuel to your engine. Take that for what its worth.I just hope no one ever has a BAP go out on them. I don't think I have ever heard of one going bad yet. Good Luck
I figure the best way to get the most and best information is to put it out there, and get some response from you guys that have been there done that. SO thanks so far, and as far as that A/F graph from the guy with the plug and Play Racetronix, I'd love to see it as well. I figure after a new fuel set up, G1 blower cam And ALky Injection, I should be just about where you are as far as HP. So I would be interested in seeing it.
Thanks Guys,
Sam.
Thanks Guys,
Sam.
Location: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
Originally Posted by vetterdstr
waiting to hear from the big HP guys who are running a stock pump as well... Fact is... there arent any...
VR
VR
Good Pointers from Bill Reid always help too.
