Z06 MAF Pushes JBSBLOWNC5 Over 750 HP (flywheel)
2017 C5 of the Year Finalist
St. Jude Donor '08
I swapped out my stock 98 Maf for an 02 Z06 maf and picked up around 20 HP. I pulled as high as 644 RWHP, and 571 RWT, but fattened it up just a tad for safety and landed in the high 630s heat soaked on the dyno.
I have a graph, but am too tired to get it on the the forum. If someone would email me at kerijoel1@comcast.net I'll email it to them and they could post it for me to this thread.
Thanks,
JB
Thanks,
JB
Supporting Vendor
1 Post
Very cool JB! Did you get the extra 20hp just by slapping the the MAF on and retuning, or did the 20HP show up immediately and you detuned it for safety?
Also, I wonder if it's a C5 vs. Z06 thing or if GM started putting this new MAF on all Vettes after a certain year?
What size is the ZO6 MAF, 85mm? Also, does it include the IAT sensor also? If it does, is there an adapter harness that will allow LS1 MAF and IAT plugs to connect to it?
Keith
Keith
Great feedback!
Vortech has always stressed how important the Intake area is in front of the compressor wheel and big gains can be found there, but I haven't experimented yet.
Did you keep the Screen in the MAF or remove it?
St. Jude Donor '08
JB
St. Jude Donor '08
Keith
Keith
JB
Did you use the Jim Pace 85mm MAF resistor calibrated for the stock LS1 MAF Table or did you use a Z06 MAF?
Did you switch your MAF tables to match the Z06 table if you didn't use the resistor mod (Jim Pace MAF)?
St. Jude Donor '08
St. Jude Donor '08
Pardon my ignorance, but what does the resistor do in this setup?
Right now it's time to go out and tear up some Canyon roads!!!
JB
St. Jude Donor '08
Ultimate Canyon Ride!!!
Just got back a bit a go from an unbelievable Canyon run!! I got some video of me chasing down a GSXR 1000 and passing him. I then was like white on rice with a brand new R1 through the canyons. The air temps were 60s and the extra 50 ponies backed up with the Meth spray was a combo like I've never experienced before!!
I probably just had my best canyon run in 6 years!!!!
I had to brake so hard sometimes coming into the turns that my brembos were smoking....
JB
JB
JB
JB
And Congrats on squeezing every last drop out of your baby!.
