Twin Turbo or Supercharger???
I've been thinking of having a Procharger setup put on but Twin Turbo's seem to be the ultimate FI mod. Are there more maintenance issues with the turbos? What is the recommended FI mod for a street car?
St. Jude Donor '06
Good luck,
Mark
St. Jude Contributor
Twin turbo hands down!
No pullies.
No belts.
Full boost around 2800 rpm.
Approx. a hundred more ft.lbs. of torque at the same boost level.
If its in your budget you can't beat the twins.
No pullies.
No belts.
Originally Posted by king_pin
Well I can tell you I have the chance to run both set ups and the TT is by far the best way to go! I see you are from Mesa I live in Chandler If you would like to see my set up let me know.....
now let's compare my set-up to yours. both of us have stock cube engines. with your 6.0 heads, I'm assuming you have about the same compression ratio that I have. mine is done with lower comp pistons and stock chamber ls1 heads though. I have home ported heads with stock valves and you have stage III cnc lpe's. you obviously have superior heads....now the meat of the story...your TTi twin turbo makes 545rwhp and 590 rwtq @ 12psi...my A&A sic D1SC makes 654rwhp and 530rwtq @ 13psi...on pump gas....looks like the tt is down 100+hp to the lowly SC even with your superior cylinder heads. ....I just don't see how tt's are better. now, don't get me wrong. I loved the sound of the bov and the sound of those turbos spooling up was almost enough to make me keep them. but the SC is just plain faster.
St. Jude Donor '06
Originally Posted by SR71
Since someone is asking for opinions, I beg to differ...I have run both also and less just say that my turbos made less than 500rwhp at 10.5 psi. before you say that something was wrong with my set-up, consider the fact that she made 525 ftlbs of torque.
Big horsepower numbers are one thing, if you have a dyno queen. What you are discounting is that turbo boost has no parasitic lose. So if 13# boost on a supercharger will almost always net less power on the same motor as a similar sized turbo. Also what you are overlooking is that turbo boost comes on faster that supercharged boost. The TTI set up with its t28 turbos are fully spooled by 2500 rpms. That means that the torque will be more than yours off the line. So while you are waiting for your boost to rev up, the turbo's torque already has you off the line. Can you please post your dyno graph and I will host Kingpins.
funny how people think turbos have no loss. I can tell you from personal experience that all the backpressure and charge contamination that a turbo creates costs power too.
as for dyno graphs, I would have to email you mine since I'm not that computer literate and have no host site. my car doesn't have the huge torque down low that the turbo does. all that torque just magnifies traction problems. with the turbos, there was no way to hook my car. it spun well through the 60ft lights on et streets. but it fell flat on it's face in 2nd and 3rd. my car hooks and leaves much better with the sc than it did with the turbos. and it pulls MUCH harder on the big end. while the turbo car spins it's tires, I will be watching it shrink in my rearview mirror.
timeslips are what count....I ran 6.907 @ 101mph(1/8th mile) on my second shakedown pass on an 85 degree day. full street weight including a 5pt rollbar, nothing removed from the car, NO powershifting and I haven't even learned how to launch the car yet. what did king pin run???
Don't be fooled by peak numbers.
I had the stage 2 turbos with the single ic. and LESS restrictive inlets. meaning a big set of K&N cones 6inches from the turbo inlets. I drove the car with the turbos for about 500 miles and it felt quick. but, on the track, it sucked! the old blower set up that made 500 at the wheels ran 99 mph....the turbos, with all their torque and area under the curve, could only muster 94.5 mph.
I fell for all of that massive torque and area under the curve crap and spent a boatload of money....only to go slower. I went turbo and then went screaming back to a blower....and couldn't be happier.
torque is great for your tow vehicle, but hp wins races!
The TTI kit suffers because of the smaller turbos, whereas the LPE stage II kit can lay down 650 rwhp with over 600 ft.lbs. of torque with 346 cubic inches of LS1.
if I need more torque, I will drive my F-250 powerstroke.
And he is still making more torque with 100 less HP and I bet he is laying down more torque and HP under the curve, the HP will rely on what trim compressors and A/R of the turbos that are included with the TTI kit.
Hrm..another apples to orange to potatoe comparison.
TTi kit was design for STOCK engines..It had been tweaked and played with to get it a bit better, but certainly can not be compared to LPE or even the old Incon kit.
So, THe TTi would really compare to a P1SC super charger. No comparsion as the TTi kit would prevail in my eyes.
The LPE would compare to the D1SC, thats a pressty good run, it would depend on the setup of each vehicle and how well the car was set up to MATCH each of the power adders attributes.
The superchargers air out well, and if the vette is setup to turn rpm it will typically win on the track.
But, Change the setup to match the turbos and its a real battle..Lower gears, taller tires will really help turn the #'s in turbo powered application.
Just my 02, Doesnt really matter to me either way, they both have the ability to beat most on the street.
Phil
Phil
Originally Posted by Sandra Bigwoode
Don't lower gears and taller tires cancel each other out?
