Crank pulley damper shift?
Old 09-05-2003, 09:08 PM
blu00rdstr
blu00rdstr's Avatar
Default Crank pulley damper shift?
Has anyone experienced damper shift? ATI has a kit to fix it, but I didn't realize it was a problem...
http://www.atiperformanceproducts.co...s/pr/30402.htm
Old 09-05-2003, 09:14 PM
blu00rdstr
blu00rdstr's Avatar
Default Re: Crank pulley damper shift? (blu00rdstr)
My bad, I'm confusing my ATIs. :rolleyes:
Interesting anyway...
Old 09-05-2003, 09:18 PM
boblackhardtop
boblackhardtop's Avatar
That is old news...You got to pin it, PERIOD.
Newer procharger kit comes w/ a pinning kit. Might want to call procharger, they'll probably send you the pinning kit w/ just shipping charge.
Old 09-05-2003, 10:53 PM
MelloYellow
MelloYellow's Avatar
Default Re: Crank pulley damper shift? (boblackhardtop)
If anyone is interested in a keywayed NEW stock damper that will work with the above ATI Pin kit, email me at: mjarnold@vsecurenet.com
I ended up purchasing the more expensive $500 Super Damper that goes with the above kit also & still have the new stocker with machined keyways.
Old 09-06-2003, 03:11 AM
blu00rdstr
blu00rdstr's Avatar
This is a case of me completely misunderstanding what I was looking at.
I thought it pinned the outer section of the pulley to the inner section to prevent movement at the rubber joint.
Old 09-07-2003, 03:41 AM
MelloYellow
There are 3 types.
1) True Keyways cut into the damper and a key cut into the crank.
2) Vertical pins, like the kit shown above, which requires squared keyways in the damper.
3) Horizontal pins, which drill into both the crank shaft and the damper at the same time horizontally.
#1 is the best but requires engine disassembly and machine work on the crank.
#2 is the 2nd best as the vertical pins go deeper into the crank than the horizontal drill and the veritical keyway in the damper has a square surface for better, deeper grip.
#3 is better than nothing (stock). It's the easiest and is what certain SC kits might include. Don't confuse ATI Performance (Damper) company with ATI Supercharger company (Accessible Technology).
P.S. I opted for #2.
P.S.S. I have a stock damper keywayed and available per Technique #2.
[Modified by MelloYellow, 3:43 AM 9/7/2003]
To Crank pulley damper shift?
Quick Reply: Crank pulley damper shift?
