Upgrading Fuel Pump- Suggestions?
Hi all. I am most likely going to be upgrading my fuel pump on my D1SC powered 01Z06. Ive been having some problems that fuel pressure dropping intermittently and need to have my tuner look at it (See this thread for the symptoms http://forums.corvetteforum.com/zerothread?id=608963) so I figured I mind as well upgrade while I am in there even if its not the pump.
With my set up (in sig) what do you recommend I go with as far as make and volume? I understand that to big is just as bad as to small correct? I am not aware of a setting in the LS1edit that will allow me to change for volume. What would be my safest bet for driving now, and would allow for expansion down the road (stroke, cam, ~650 RWHP goal).
Lastly is it common for a pump to go at only 6k miles or so? I rarely beat on the car. Or perhaps we will find another problem?
Thanks for listening..
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Re: Upgrading Fuel Pump- Suggestions? (boblackhardtop)
The Racetronix comes with a very nice plug and play harness with a seperate power source for the higher amps that the pump draws.
Re: Upgrading Fuel Pump- Suggestions? (CHRIS NJ C5)
Walbro makes the stock pump too, so they're not all the same pump. Not to say the Racetronix and LPE are/aren't the same, but I'm pretty sure they are different. I compared them a bit when we swapped them out and there were some minor visual differences.
Either way, my LPE was worse than stock. Could have been a bum pump of course. Just realying what I experienced.
Re: Upgrading Fuel Pump- Suggestions? (Rookiedyn)
I went with the Aeromotive A1000 pump and pump controller. It fits under the rear wheel well liner. It makes noise but when you drive down the road, it mixes in with all the other noise and you dont know it is there.
vetterdstr :cheers:
vetterdstr :cheers:
Re: Upgrading Fuel Pump- Suggestions? (vetterdstr)
Vetterdstr, how can you stand that noisy fuel pump. Andy installed that thing on my car and I had it removed about ten minutes later.
I would recommend the Walbro or Racetronix with the Kenne Bell boost-a-pump.
Try mounting it on some 1/8" thick rubber. Or order some rubber standoffs from McMaster so that even the bolt is isolated.
vetterdstr :cheers:
vetterdstr :cheers:
Re: Upgrading Fuel Pump- Suggestions? (BlownZ06)
It really isnt a problem for me. I will try the isolators when I tear everything apart next time to put an end to the vibration at an idle.
vetterdstr :cheers:
vetterdstr :cheers:
Thanks for all the input guys. It looks pretty straight forward. Although I knew vetterdstr would chime in with something unique :) I will look into that pump as well.
I wasn't sure if I needed a certain volume pump etc. I was looking at the RX-C5LS1-FPK-2 from Racetronix. If any forum vendors or you guys want to chime in with a good place to purchase from I would appreciate it.
thanks!
thanks!
You pretty much want the most volume you can get.
There is one downside to a high volume pump. The pump pushes the same amount of fuel at all times (with a constant voltage) and the regulator keeps the pressure constant at the regulation point. The unneeded volume goes back into the tank. This has the negative effect of heating the fuel faster than a low volume pump would.
Re: Upgrading Fuel Pump- Suggestions? (QuickSilver2002)
This is the advantage to the Aeromotive setup... You can adjust the controller to kick into high hear (pumping more fuel) at say 3,000 rpms. This way the fuel is not being pumped to its maximum until you go over that rpm...
vetterdstr :cheers:
vetterdstr :cheers:
Supporting Vendor
The temperature rise caused by the fuel pump's higher volume over stock is so minor it can not even be quantified. You guys are barking up the wrong tree with this theory. The ambient temperature around the fuel tanks and lines has a 100x greater effect on fuel temps when compared to the pump alone.
The Aeromotive pump will not flow as much as the Walbro pump using the same factory lines. The Aeromotive's life span is only a fraction of the Walbro's. Using the Aeromotive pump will defeat the purpose of the fill bucket in the tank which is used for high-g fueling.
If you want a pump booster that varies its output linearly based on manifold pressure consider the MSD unit.
The Racetronix and LPE pumps although both made by Walbro are not the same.
Jack :cool:
Racetronix
Jack :cool:
Racetronix
Re: Upgrading Fuel Pump- Suggestions? (Racetronix)
Racetronics, I appreciate what you are saying and since you sell this stuff for a living I believe what you are saying 100%. The Aeromotive pump and controller on my car was sold to me when I upgraded to the Stage II S/C setup I have now. What I am doing is simply talking about what I have and how it works. I am not saying it is better than other systems. I will certainly "upgrade" to another system when mine goes down the tubes "and from what you are saying, that should be soon"
Best of luck to everyone in their mod decisions. :blueangel:
vetterdstr :cheers:
vetterdstr :cheers:
Supporting Vendor
Try to stay away from fuels that contain high concentrations of alcohol as this will shorten the life of your Aeromotive pump greatly. When running an Aeromotive pump you should have a pre-filter on the suction side to protect the pump and a small particle filter on the output to prevent debris from clogging your injectors.
Jack :cool:
Racetronix
Jack :cool:
Racetronix
Jack :cool:
Racetronix
Jack :cool:
Racetronix
It seems that the fuel temp change would be significant for cars that actually push the fuel up to the fuel rail where it gets pretty darn hot.
Again, I'm no expert, but I think this is one of the reasons GM moved the regulation point back (trading one problem for another). My understanding is that evaporative emissions are one of the worst problems in today’s cars.
Supporting Vendor
Perhaps this is one of their reasons although it is a sealed system. The cost savings would be a more likely consideration as the fuel system component count is reduced.
Either way it makes serious problems when building HP.
Jack :cool:
Racetonix
Jack :cool:
Racetonix
The '03 service manual describes the new FSS "on-demand" fuel system and claims the change was to reduce evaporative emissions that are higher in return-line systems that expose fuel in fuel rail to heat and return the heated fuel to the tank.
But like Jack said, it is a closed system so it may be GM's PC answer for reduced components and cost. Sure ups the the labor rate on tank r&r when you have to r&r the powertrain. Guess I'll do the clutch while I'm looking at it.
