Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2003, 09:38 AM   #1
0BreathlessPerformance.com
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Default Just out!!! BPPs Twin Turbo System for the LS1 & LS6
Here is some information on our twin turbo kits out for the 97 and up Vettes.
http://breathlessperformance.com/products/500-101.asp
BPP's C5 Corvette 1997 – 2003 - Twin Turbo Kit - Stage 1
Hp rating based on stock C-5 with cats on and Performance catback exhaust
Stage I - 550+ Horsepower Package – 6 psi
· Twin Custom/Hybrid Turbochargers (one year warranty)
· 321 Stainless Steel Turbular Headers (lifetime warranty!)
· Twin Tial 35mm wastegates with 6 psi base setting
· Single front mounted high efficiency intercooler
· Aluminum intercooler plumbing
· Nomex intercooler hoses
· Stainless high torque hose clamps
· Upgraded Radiator front mounted
· PCM programming
· Upgraded fuel injectors (42ib/hr)
· Boost gauge and mounting plate
· Boost controller
With a cylinder head and camshaft upgrade, this package can handle up to 650 RWHP with a proper fuel system and tuning. Racetronix fuel pump upgrade required for more than 500 RWHP applications.
BPP's C5 Corvette 1997 – 2003 - Twin Turbo Kit – Stage 2
Stage II UP TO 950+ Horsepower – 7-15 psi
This package is designed to work in conjunction with a long block capable of supporting high horsepower. 9:1 static compression is recommended. Supporting driveline and safety upgrades are required.
· 321 Stainless Steel turbular headers (lifetime warranty!)
· Twin Tial 35mm wastegates with 7 psi base setting
· Single front mounted high efficiency radiator
· Upgraded fuel pumps
· Upgraded billet adjustable return style fuel pressure regulator
· PCM programming
· Upgraded fuel injectors (50lb/hr)
· Electronic boost controller
Thank you, Ernie
:cheers:
BreathlessPerformance.com is offline   Reply With Quote
Old 01-13-2003, 10:19 AM   #2
fredl11
CF Senior Member
fredl11's Avatar
Send a message via AIM to fredl11
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (BreathlessPerformance.com)
Very Interesting!! Cannot access site though..
fredl11 is offline   Reply With Quote
Old 01-13-2003, 10:27 AM   #3
Jack R. Stein
CF Senior Member
Jack R. Stein's Avatar
Send a message via AIM to Jack R. Stein
Will you have a couple of these setups on C5's at your drag racing event on
February 9th? If so, will they be set up with ET streets, gear, etc to show us that they can get traction and hit upper 120's and mid 10's?
Jack R. Stein is offline   Reply With Quote
Old 01-13-2003, 10:31 AM   #4
Godspeed
CF Senior Member
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
The link doesn't work and what is the pricing?
Godspeed is offline   Reply With Quote
Old 01-13-2003, 10:33 AM   #5
jpas
CF Senior Member
The link at the bottom of his post works. This system looks awesome!!! Good price as well.
jpas is offline   Reply With Quote
Old 01-13-2003, 10:38 AM   #6
LuvmyC5
CF Senior Member
St. Jude Donor '05-'08
LuvmyC5's Avatar
Great price for twins! I don't really care for the clothes dryer air intake tubes. If you could figure a way to run them through the front end, and possibly hard pipe them. It might cost a little more, but it would look better, and not have the sharp bends in them. I like it though! Can't wait to see how it runs!
[Modified by LuvmyC5, 12:47 PM 1/13/2003]
LuvmyC5 is offline   Reply With Quote
Old 01-13-2003, 10:41 AM   #7
Austrian Vette
CF Senior Member
Support Corvetteforum!
Austrian Vette's Avatar
Send a message via ICQ to Austrian Vette
If I would have known about that turbo setup earlier, then I would have Shirl built my 422 iron block for that. :(
Now it΄s built for nitrous......
Nice setup!!!
Michael
Austrian Vette is offline   Reply With Quote
Old 01-13-2003, 11:41 AM   #8
STAGED
CF Senior Member
Wow. The Stage I kit should safely break 130 mph traps with traction thru cats on pump gas. Off-road pipe, more boost, race gas program, better fuel pump should net near 140 mph traps based on past experience between restrained boosted setups and race gas off-road boosted setups.
STAGED is offline   Reply With Quote
Old 01-13-2003, 11:48 AM   #9
Godspeed
CF Senior Member
Senior Member
Ernie, the kits looks great. Are the orange or black intake tubing the final pieces? Are there going to be any hardpipes and silicon tubing for for the intake? Or would it be possible to route the intake pipes down below out of view for a more stealth look? The kit and the prices looks great, looking forward to some dyno and track #'s. Time to start pinching some pennies. :cheers:
[Modified by Godspeed, 10:52 AM 1/13/2003]
Old 01-13-2003, 12:09 PM   #10
CF Senior Member
Cruise-In I Veteran
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (STAGED)
Our R&D Road race car is currently being setup for the twin turbo conversion from supercharged. We hope to have it done for the NCRS show and our Drag race event.
We will have the kits complete within the next couple of weeks.
Thank you, Ernie
BreathlessPerformance.com :thumbs:
Old 01-13-2003, 12:32 PM   #11
Sean@OCCorvette
CF Senior Member
Dyno Please.
:cool:
Sean@OCCorvette is offline   Reply With Quote
Old 01-13-2003, 02:23 PM   #12
bill mcdonald
CF Senior Member
What size are the turbos on the Stage 2 system?
950 HP at 7 psi base setting? How much boost to make 950 HP? or is this just what the system should be capable of using these turbos?
Any plans to try doing this on a C4 platform?
[Modified by bill mcdonald, 11:24 AM 1/13/2003]
bill mcdonald is offline   Reply With Quote
Old 01-13-2003, 02:49 PM   #13
Bill Reid
CF Senior Member
Bill Reid's Avatar
Is this not the same system that bc53 has on his ride?... produced by the folks at LS1Speed? At any rate nice looking package. Looks like more room to work with... including larger turbo's if customer so desires. Intake ducting needs work, IMO :blueangel: Ernie, is there anything in the works like wire reinforced silicone, composite, or aluminum ducting that can take the place of the current intake setup?
:cheers:
(edited for content) :)
[Modified by billreid1@***.net, 1:26 PM 1/13/2003]
Bill Reid is offline   Reply With Quote
Old 01-13-2003, 02:54 PM   #14
Z06GMAN
CF Senior Member
St. Jude Donor '06
Z06GMAN's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (billreid1@***.net)
:smash: :smash: :cheers:
Z06GMAN is offline   Reply With Quote
Old 01-13-2003, 03:03 PM   #15
SlowC5
CF Senior Member
:cool: :cool: :cool:
SlowC5 is offline   Reply With Quote
Old 01-13-2003, 03:03 PM   #16
Phil97SVT
CF Senior Member
Phil97SVT's Avatar
Send a message via AIM to Phil97SVT
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (Z06GMAN)
Nice looking kit....Anyone want to change the plugs?
Phillip :lol:
Phil97SVT is offline   Reply With Quote
Old 01-13-2003, 03:31 PM   #17
supercoupe01
CF Senior Member
supercoupe01's Avatar
Nice to see options in the high hp area. :yesnod: :yesnod: :yesnod: :yesnod:
supercoupe01 is offline   Reply With Quote
Old 01-13-2003, 03:35 PM   #18
CF Senior Member
Cruise-In I Veteran
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (Phil97SVT)
For the stage 2 you would need to have your engine prepared. When we say 950 Hp+ we mean the CFM flow of the turbos will be enough for over 950HP
When we put our car on the dyno we got 820 RWHP on the procharger supercharger F series on 10 Psi. On a turbo car you do not get the drag of having to spin the turbine on a pulley (which in some cases takes over 80 HP) you simply use the exhaust gases.
As for the turbos they are hybrid t-32s on the stage ones.
Thank You, Ernie
Old 01-13-2003, 06:20 PM   #19
RogerM
Junior Member
Send a message via AIM to RogerM
Wow very impressive i'll keep my eyes peeled :lurk: :lurk:
RogerM is offline   Reply With Quote
Old 01-13-2003, 08:10 PM   #20
flynbludream
CF Senior Member
flynbludream's Avatar
Do those prices include install? If not what is the total price turn key?
flynbludream is offline   Reply With Quote
Reload this Page Just out!!! BPPs Twin Turbo System for the LS1 & LS6
Tags
2003, corvette, godspeed, kit, kits, ls1, ls6, nitrous, single, size, stage, systems, turbo, turbocharging, twin, twinturbo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
