Just out!!! BPPs Twin Turbo System for the LS1 & LS6
Old 01-13-2003, 08:25 PM
NJ99FRC
NJ99FRC's Avatar
Location: If you can see the car behind you, your not going fast enough
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (flynbludream)
OMG! :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: 950 HP! is that from a stock engine? Is that at the rear wheel? IMAGINE IF THAT WAS ON A 427! :eek: Good job guys! :hurray: :steering: :hurray:
Old 01-13-2003, 08:58 PM
AP
AP's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (ny vette lover)
Cool Kit ... like other's have said ... the hoses look kind of cheap ... otherwise ... it is probably going to be a popular package ...
Old 01-13-2003, 09:55 PM
ChrisTinaBruce
ChrisTinaBruce's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (AP)
FINALY, WOW, a TT under $12K. Thank YOU, Thank YOU. My only question is one asked about the piping. Will it be hard silicone or run another way.
Great Job.
Old 01-13-2003, 10:24 PM
MelloYellow
MelloYellow's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (DallasC5)
Looks like the CAS kit is getting around:
http://forums.corvetteforum.com/zerothread?id=404432 http://forums.corvetteforum.com/zerothread?id=461813
I'm pretty sure BPP's above motor with the F Series Procharger has larger 4xx cubes. Someone just needs to make some piping or hoses for that kit. Maybe do something different with the air filters too.
[Modified by MelloYellow, 10:28 PM 1/13/2003]
Old 01-13-2003, 11:03 PM
0Mike@NorrisMotorsports
Former Vendor
Mike@NorrisMotorsports's Avatar
St. Jude Donor '11
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (MelloYellow)
Hey Ernie,
I believe this is it here:
http://www.ls1speed.com/catagory.cfm?catagory=new
Just need to scroll down a bit. Pricing is for the kit only, not labor per LS1 Speed. Definitely needs better duct work, but promising for sure. Time will tell and good luck. We are looking into this also.
Mike
Old 01-13-2003, 11:11 PM
bc53
bc53's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (billreid1@***.net)
Yes this is my car that is in the pic and is the first C5 done with the kit.
Bill F.
onfire
onfire's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (Vette Doc)
What type scavenge pump is used?
Old 01-13-2003, 11:12 PM
Bill Reid
Bill Reid's Avatar
Be nice to get an update from bc53... you out there bud? As far as I know he is the only forum member currently with this kit installed.
Old 01-14-2003, 11:02 AM
Godspeed
Godspeed's Avatar
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
So I am confused now. :confused:
Is this a BPP kit or a CAS kit? Or will BPP be a distributor of the CAS kit? Please post up as soon as you have more information regarding the inlet hoses.
Old 01-14-2003, 11:09 AM
GR8-LIFE
GR8-LIFE's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (BreathlessPerformance.com)
Boy I can feel the SC market going "plop!" Very very good Job Ernie. Lots of luck with this!
Old 01-14-2003, 04:02 PM
Shinobi'sZ
Shinobi'sZ's Avatar
Is the intercooler a "spearco"?
Old 01-14-2003, 04:10 PM
jpas
jpas's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (Shinobi'sZ)
Shinobi - Are you interested in a front mounted I/C? I am making my own that will have two inlet ports on the bottom corners and the outlet port will be out the center of the top. Let me know. The cores are made by the same company that brazes the Spearco cores. The cost is MUCH less.
Old 01-14-2003, 04:14 PM
  #33
Shinobi'sZ
Shinobi'sZ's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (jpas)
Dude (jpas) YES!
I was thinking of either doing it that way or having a single inlet from the side. I think the less tubing and bends/connections the better. But I am definetly interested.
Interestingly,
I took all the blower kit off of my car awhile back (when the motor blew) and was not able to place the airfilter intake and air bridge on the throttle body, because it would run into my relocated rad. So what I ended up doing was sticking the maf right on the throttle body and then a votex airfilter on the other end of the maf (looked like one of those Vortex or TPI motors when they stuff them in a truck). The Car ran great I drove it for 100 miles to the dealership...you could not even tell the pistons were cracked driving it around N/A. My point is..is that you with a single intercooler and plumbing you connect the MAF right on the TB with a coupler and it works fine.
[Modified by Shinobi'sZ, 3:27 PM 1/14/2003]
Old 01-14-2003, 05:40 PM
  #34
NEPTUNEBILL
NEPTUNEBILL's Avatar
I would be interested in a single IC as well and like Shinobi I was more interested in a single in and out to eliminate a lot of tubing--When Ive seen other large single IC's I always wondered if it would block air to the radiator it gets hot here---thanks bill
Old 01-15-2003, 08:39 AM
  #35
Rx7Rob
Rx7Rob's Avatar
SWEET!!
Single intercooler so I don't have to give up my brake cooling, YES!
Did I miss it, which turbos are on the kit?
What dia are the down pipes?
We're almost down to where I might consider the twins!
Is a program/fuel map supplied? [nevermind, I see that it is]
Why, the major price increase over the F-body kit??
[Modified by Rx7Rob, 8:40 AM 1/15/2003]
Old 01-15-2003, 06:32 PM
  #36
0Sales@MVPAutoParts.com
Former Vendor
Sales@MVPAutoParts.com's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (Rx7Rob)
SWEET.... :smash: :smash: :smash:
Old 01-16-2003, 09:53 PM
  #37
bruce1
bruce1's Avatar
Default Re: Just out!!! BPPs Twin Turbo System for the LS1 & LS6 (Tuan Le)
I want one!
Maybe in my next life.
Old 01-17-2003, 11:31 AM
  #38
0BreathlessPerformance.com
Former Vendor
BreathlessPerformance.com's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
We are working on redesigned tubes for the intake.
Thank you, Ernie
Quick Reply: Just out!!! BPPs Twin Turbo System for the LS1 & LS6
