Mellow Yellow, PCV check valve question
Regarding http://forums.corvetteforum.com/zerothread?id=327801
I'm curious about adding a check valve to get rid of oil coming out of the valve cover line.
In your post it says to install the check valve in the PCV line. What I'm wondering is, you said the line that oil is coming out of is a fresh air line, is there any reason not to install the check valve in this line instead? So that air can enter the valve cover, but oil can't come out.
Re: Mellow Yellow, PCV check valve question (SomeDay)
You want to completely Cap the Throttle Body Fresh Air line (the throttle body nub, not the valvecover nub) for an FI setup. You then re-route the fresh air nub to a breather or better yet in FRONT of the blower but behind the MAF if possible. I don't think you can do that with an ATI, so I'd use a breather there. For the Vortex the kit addresses this, caps the TB and re-routes the fresh air exactly as I mentioned.
re: the PCV, it is a weak check valve. It will be forced open under boost, pressurize the valvecovers, then shoot out oil thru the fresh air intake nub. To prevent that you put a check-valve in place of the PCV or in front of the PCV, between the PCV and the TB PCV hole. You point the arrow towards the TB on the check valve.
[Modified by MelloYellow, 4:06 PM 1/3/2003]
