Ragin Racin built C5 Corvette TSP 383 stroker / A&A Supercharger (PIC's)
Built By RAGIN' RACIN'
-2001 Corvette C5 with 27,000 original miles
Texas Speed & Performance 383ci Engine 10:1 compression
-TSP 230/242 .600 .600 114lsa +2 Cam (Engineered By "Pat G" for Application)
-Texas Speed Forged 4340 Crankshaft, 6-Bolt Flange
-TSP 6.125" Super I-Beam Forged Rods w/ ARP L19 Bolts
-Wiseco -15cc Dish Forged Aluminum Pistons
-Wiseco Tool Steel Wrist Pins
-Johnson 2110r Lifters
-Rollmaster Billet Timing Gear Set & Chain
-Melling oil pump 10296
-All new GM sensors / new GM water pump / all new GM seals & gaskets
-TSP Chromoly Pushrods
-ARP Main Stud Kit / ARP Head Stud Kit / ARP accessory mounting bolts / ARP clutch bolts
-Improved Racing C5 Corvette "Batwing Oil Pan" Crank Scraper
-FAST 92mm Intake w/ LS7 Throttle Body
-Stainless Braided Hose Steam Vent Kit For Cylinder Heads
-60lb Injectors
-Gen IV Engine Block w/ 24 Reluctor Wheel
-PRC 220cc "CNC" Heads, Flow 315 CFM Intake / 230 CFM Exhaust @ .650
*62cc, 2.045" Intake / 1.600" Stainless Valves, TSP .660" Dual PAC Spring
Kit, Ti Retainers, TSP 1.72" Roller Rockers w/trunion upgrade
A&A V3 Ti Trim Supercharger Kit
-A&A Secondary 8-rib Belt Drive System
-Innovators West 10% Overdrive Crank Balancer
-A&A 3.6" Supercharger Pulley
A&A Fuel System Single Pump Kit w/ Regulator And Stainless Braided Lines
-Racetronix 255 Intank Pump Upgrade
-Racetronix Fuel Pump Wire Harness
-ECS billet C5 fuel block for gas tank connection
Snow Performance Stage 2.5 Methanol Injection Kit
-Stainless Braided Lines
-Tig Welded Intake Bungs
Gauge
-Snow Digital Meth/Boost Pillar Gauge
-Autometer Analog Boost Gauge 0-15psi
-Autometer Dual A-Pillar Pod
Dewitts Radiator
Dewitts Dual Spal Fans
McLeod RXT Ceramic Clutch Kit
-McLeod Billet Steel Flywheel
-New GM Slave Cylinder
-New GM Master Cylinder
-Tick Bleeder
-ARP Bolts
WilWood 6 Piston Aero6 Brakes
-GM C6 Z06 Cross Drilled Rotors
-Wilwood Stainless Brake Lines
Aldan American Coilover Suspension
- 600LB Front / 550LB Rear-Track/ Auto-X
TPS Sway bars / End links / Polyurethane Bushings
HPI Driveline Solid Mounts
ECS Transmission & Differential Brace
Billy Boat Bullet Exhaust
Texas Speed & Performance Long Tube Stainless Headers
-Catless X-pipe
-ARP Header Bolts
Drivetrain
-GM T56 Transmission
*Hurst Shifter & Ball with Bronze Cup Bushing / C5 cnc solid mount shifter box bushings by Lucky Garage
-GM 3.42 Rear Differential
*New Output Axle Seals Replaced During Build Process
-GM Z06 Spec 12mm Driveshaft/Torque Tube w/factory GM Couplers
Wheels & Tires
-BC Forged RS45
19x10
19x11
-Nitto drag radials
-60lb Injectors
Gauge
Dewitts Radiator
-Tick Bleeder
-ARP Bolts
-Catless X-pipe
-ARP Header Bolts
Drivetrain
Wheels & Tires
-BC Forged RS45
19x10
19x11
-Nitto drag radials
lsxcameron (03-11-2022)
Eshoremd (03-28-2023)
Banned Scam/Spammer
Very solid build, with some very nice parts. Any idea as far as hp goals? I'm assuming 93 + meth as far as fueling, that 383 should yield some pretty solid pump gas numbers! This was pretty much the exact route I was going to go until I picked up my 427. Excited to see the results man
Running Guns & Moonshine
Loving this combo and the engine ****. It's a pretty darned close combo to my own. Does the TSP block offer longer sleeves at all? That's one thing I'd have gone back and done differently if I had known I was going to snowball from a basic blown rebuild to something more dedicated is opt for a better aftermarket block.
Eager to see this run and what numbers you pull out of it.
Vortech V3 Ti trim Spec's:
Max Speed: 52,000rpm
Max Boost: 26psi
Max Flow: 1,400cfm
Max Power: 950HP
Peak Efficiency: 75%
Discharge OD: 2.75”
Inlet OD: 3.75”
Inducer Diameter: 3.51”
lsxcameron (03-13-2022)
See? We're more alike than we thought. I'm also running an LS2 block. I will be curious to see where we end up shifting in relation to engine vs head unit rpm. Either way, this general combo is apt to make more power than either setup will easily put to the street and in my case I can see pulleying up a bit. Ysi is a solid option for the future. In my case the car came with the cathedral headed 225 prc, so in the future I can always opt for the rec port to upgrade. And some companies offer different impellers and bearings for the Ti as well.
PK Auto Design
$3250 for BC Wheels (Wilwood big brake fitment)
19x10 +57
19x11 +60
Nitto 305/35R19 through tire rack
Right now I currently have them on my other LSx454 C5 Z06 and dropped this car off with my cheaper Forge Star Wheels. I might sell the Forge Stars and buy another set of BC's once I get the car back.
LINK to my other LSx454 C5 Z06....
RAGIN' RACING... C5 Z06 build (LSX454 swap / A&A Supercharger) PIC's - CorvetteForum - Chevrolet Corvette Forum Discussion
Tusc (03-13-2022)
The following 3 users liked this post by C6-LS2-MN6:
Love the build! You will probably be at the limit of your fuel system if you are using 93 or may not have enough. If you are using E85 you don't have enough. I would also expect the 60# pound injectors will be just about maxed out.
I made 710rwhp on a 403 with A&A TI3. You have better heads and will be pushing more boost. I'm running a 525 pump. My 80# injectors are running at 70%.
Also don't let the meth system be the band aid. Just my two cents.
KT
KT
Tusc (03-21-2022)
KT
KT
A&A Fuel System Single Pump Kit (rated @ 800hp)
*Plus Snow Meth kit
93 only here! I would NEVER run Ethanol through my expensive builds. Too many long term issues with minimal gains for me. Maybe right for others, but not me. Ethanol has a corrosive action on fuel-system components, magnesium, aluminum and rubber. In the long term it can and will affect fuel hoses, fuel pumps, gaskets, seals, fuel filters, fuel injectors, throttle bodies...ect. Also, E85 (Ethanole gas) can have a short "shelf life" due to being very hygroscopic (attracts water) and I wouldn't recommend letting it sit in your tank if you don't drive your car often and the E85 concentration from different gas stations can be an issue if your car is tuned on the edge for E85.
