QQ on A&A V3SI 6 rib belt replacement
Guys,
Just have one question....I have a squeak coming from the belt area so I plan to troubleshoot today....My question is, can you remove the belt simply by using the locking pin in the billet A&A tensioner or do you need to loosen the slider by the SC as well??? I know when I originally installed the belt it was quite tight and I figured you may need to adjust both to get the belt of easier.....Just an quick easy question....
Forget it....All done.....
I loosened the belt swapped an idler pulley and put the belt back on. I did find a bolt loose on the power steering pump but think it was the belt. It soubded better after i put everything back. Will need to see how in goes over the few weeks...
