Pulley Alignment
Pulley Alignment
All,
I have a old procharger twin intercooler setup. Wonder if anyone has this setup. Need some help/suggestion on a pulley alignment issue I'm having.
Thanks in advance.
Thanks in advance.
I am not much help at pulley alignment but if you stated the problem, others would be able to give you advice.
Here is a link if you have not seen about using a lazer aligner.
Laser alignment of serpentine belts the right way - CorvetteForum - Chevrolet Corvette Forum Discussion
Thanks. Don't mind the scoring of the idler pulley. That is a mess up on my part. Having an alignment issue with the idler pulley and the pulley on the procharger. Almost like a shim is missing on the tensioner side. Bought the kit used so not sure if I'm missing something.
ATI shows the tensioner pulley misaligned with the charger pulley as well. What directions?? LOL. Wife to me to pull them out of the trash. All is good Attachment 48317435
It’s just a back side idler. Just space it over- doesn’t need to be perfect, just try to get the belt in the middle and see it anything else is misaligned.
