New Short Block or Rebuild?
Shortly after boosting my 2001, I blew out the rings.
So, I plan on having the bottom end rebuilt/upgraded. I am going 383 with forged pistons. But before I pull the motor, drop it off and wait 2-3 months for the shop to do the work (they have a backlog); I was curious is anyone could suggest a short block that I can order? I would love to get it back on the road sooner and maybe ordering a new short block is the way to make that happen. Doesnt have to be stroked. I was only going 383 its just a small cost difference during the rebuild.
I appreciate the help/suggestions!
Texas Speed and Thompson Motorsports are the first two that come to mind when thinking about shelf stock short blocks. I've never dealt with either of them but I know a lot of people have with varying results. I'm not a fan of 4" stroker cranks for a variety of reasons so I'm always going to suggest getting your cubes elsewhere. If you don't mind the added weight you can get larger OEM iron blocks for a decent bit less than an aluminum block.
I checked with Thompson, they are 2-3 months out on shipping. I just want my car back
Call Texas Speed and tell them what your goals are and listen to their suggestions. I bought a 402 short block from them 3 or 4 years ago and love it. Low end, not in boost is a beast with the right cam. My cam is. 630/.649 so not small but good on a larger cubic inch motor.. In boost its a monster.
Chris
Chris
I was in the same boat. Went with a iron block and reused the top of my motor (02z). I put the money into the fuel system, crank, rods, pistons, and customs rings...strapped on a ysi and now boom 800rwhp...
We show to have a forged piston and rod in stock if it helps. We should be more like 6 weeks at the moment to build your existing block, I realize you want it quickly but please let us know if we can help in any way. Thank you sir!
The following 3 users liked this post by Thompson Motorsports:
My engine builder recommended not going a stroker with FI. He went into detail as to why, but it was over my knowledge level so I can't repeat why he suggested otherwise. But in short he said a stroker with FI will have a drastically shorter life span.
I opted to pick up a 6.0 iron block to get a little extra cubes and going a complete forged setup with custom cam. I gave him the details of my car and how I use it and left the rest up to him. All I know so far is it will be a 3.900 crank and a 6.125 rod combination and he's promising that it will be a bad bitch. Ha.
Epic.
What about the likes of ATK or Blueprint, would they have short motors in stock ?
Probably not great value for what they offer, but they might be available fast, and lets face it stock bottom ends have gone very far, especially the later Gen3 or Gen4 stuff.
https://www.gmperformancemotor.com/parts/19370163.html
https://sdparts.com/i-24137408-chevr...te-engine.html
https://sdparts.com/i-24080765-blueprint-engines-bpls3640-364ci-ls-shortblock.html
Or locate a similar used short motor or engine from somewhere ?
I saw something on your website. Sending you a message.
ForceFedC5 (10-14-2020)
6 weeks is a long time. summit ships parts in 2 days
I have 2 engines ready to go
4.8 iron short block block, 020 over wiseco pistons, gen 4 rods with new sps bolts, stock std crank. $2850 handles 900 hp with solid reliability
5.7 LS6 turbo engine 9.5 wiseco pistons, scat h beam rods, stock 3.622 std crank
ls6 intake with 80 lb injectors (or 127 bosch new), BBk 90 MM tb (no boost issues)
AFR 225 mongoose heads, comp cam roller rockers, comp 5/16 7.4 .080 pushrods, stainless race valves
ls6 batwing with drain backs for turbos just freshened up NO miles
this engine is designed for 1100 hp with the TTIX kit $6500 from intake to pan, ready to drop in
and if you want at the same time
TTIX twin turbo kit. cast turbo manifolds, intercooler, with pumbing, and the hot tip 3" champion down pipes (will sell separate new)
ball bearing 62 turbos, complete c5 exhaust system (borla stinger)
bolt in with the above engine and 1k hp awaits I need $6500, will sell for 12k for turbo system and the engine
This engine makes a dyno proven 800 hp at the tire at only 18 psi boost. much more power with e85
KT
I'd stick with 3.9 or less stroke and keep the pistons up in the block I know the new stroker pistons work pretty good, but I'd rather go with more progressive torq that builds and rev a bit higher
if you need a lunati 4.0 crank, I need $700 for it new in box. I'm sticking with stock stroke as hooking up 800 ft lbs at 3600 is hard enough already!!
