*** C5 High Horsepower Club ***
chriswtx (12-04-2019)
#45
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Update for me! Just picked her back up today after nearly 5 months at the tuner (winter storage he called it, lol). This was the hail mary pull at the ragged edge of the fuel system capabilities at 17 PSI. Fuel system coming along with 4 figure numbers one of these days when I get to it.
nfantbabyjesus (05-06-2020)
#47
that's a really strange readout... if hp & torque are on the same vertical scale and overlayed across the same RPMs, shouldn't they cross at 5252?
and then the torque reading is much higher than the hp (atypical for a centri), and the numbers don't calculate to the estimate at the bottom.
or is it something to do with the correction method that i'm unfamiliar with? i'm so confused right now.
#50
Pro Mechanic
@Vette97sc I have you updated!
I was just looking at my graph......I really need to do my fuel system, that car flatlined just over 900. I think it could have gone closer to 950 looking at the curve if it hadn't been out of fuel.
#51
and i forgot to say congrats the 1st time... hitting 4-digit power ain't no walk in the park!
#52
Received 1,261 Likes
#53
Pro Mechanic
Nope, 93 and meth right now. Need to build a fuel system and retune for that first and with a little more boost and proper fuel it should crack 1k on the 93. After I get that done I'll save up for the injectors and swap it to E85 down the road.
#54
Cam is A&A Corvette stage 3.
#55
any reason you aren't just going straight to e85?... injectors to handle that kind of power on ethanol are expensive so if it's money I get that
#56
Pro Mechanic
#59
Pro Mechanic
Updates have been made!
@C5-Fan What that pull at 28ish lbs of boost judging by that cut off lower graph? I'd like to know a little more about your setup, it's impressive.
#60
Dart LS SHP Pro Block
Unported Dart LS3 Pro 1 heads (6bolt)
Dual keyway 4340 crank
Manley boost rods
Wiesco blower pistons with pin upgrade
Comp Cams roller cam & shaft rockers
Morel lifters
Cometic MLS gaskets
Melling M select pump
Rollmaster timing chain
Aeromotive 3.5 pump & regulator
Holley Sniper low profile intake
90 mm LS2 throttle body
A&A kit with 10 rib & secondary drive ( on E85 ) Ysi-B head unit
2.75 pulley and 10% overdrive balancer
ARH 2 inch headers with custom 3.5 exhaust
Holley Dominator ECU (it read only 25 PSI on that pull)
Racepak IQ3 Dash
RPM Stage 4 C6 Z06 rear diff
RPM Stage 4L80E Trans
PTC triple disk converter
DSS 1500 HP torque tube & couplers with billet cone and drive plate
Carbon Fiber cowl hood
Weld RTS Wheels with 15x10 beadlocks on rear
Wolf Racecraft Cage - good to 8.50's
I have no idea what it will run but I plan on taking it to the track in 2 weeks for a Street Car Shootout.
HotRod Junkie (11-28-2020)
