Texas Speed 427 and F1A Build
#181
Easiest IC upgrade would just be as big a Garrett core as you can fit in the space you already have, or a direct core-core replacement only for your existing end tanks.
Or go full custom.
But if top speed is your main goal, then the aero considerations could be considered and going A2W.
if it's just a fast car you can use anywhere and everywhere...I'd keep it simple with A2A.
Or go full custom.
#182
I would definitely look into aero to ensure there is no lift, and ideally downforce. I wouldn't be concerned with trying to make the car lighter
#184
Agreed on the aero honestly the car is as light as it is gonna get right now weighs about what a stock Z06 did from the factory. I will loose a few pounds when I remove the C02 crap and will gain a few back when I do lexan side windows. Its a give and take to say the least. At this point the longer 2.7 mile distances are a ways off a year or so I would say at best. Gonna go a couple half mile events and 1 mile event next year for sure. Just happy I got this event in and the combination actually worked.
#185
All ready for hibernation. Need to change the oil and drain the E85 and place some 91 with stable in it. Could also use a detail granted it needs a paint job if I am honest. LOL Would like to tackle the lexan windows this winter but we shall see.
poopinpenguins (08-27-2020)
#186
Thanks man appreciate it that was the final run for the vette there, I have no desire to go those speeds again on that road. I did not see you this year?
#188
Would you mind me asking what rear end do you have ?!!
how you achieved 187 MPH in 4th !!
#189
I have a 2.93 rear end with a 27.3 inch tall tire. At 7,100 rpm I max out right at 197mph in 4th. My plan next year is to try some halfmile events and see if I can get a 190mph half mile.
#192
So you still have C5 trNny with 27 spline output shaft because I dont think any vendor have 2.93 for C6Z06 diff
#193
ForceFedC5 (03-19-2021)
#196
those window braces give me an idea Some suction cups on the end of some nice little linkages to hold the %*&$# windows in place at speed
that lexan setup looks like it will do the deed and hold things in place. Very cool setup.
#200
