Gear change or not?
Gear change or not?
Getting ready to have my rear differential rebuilt do to gear noise, currently I have 3.90 gears which were installed when car was still naturally aspirated now car is supercharged so was wondering if I should now go with 3.73's or even go back to the 3.42's?
Car is an occasional go out and play car, I've done one track event 1/4 mile. Car current sits on CCW sp500's 19x10 & 19x11's rear tires NT05 dr's. During the track event did no burnout, staged left off idle and managed a 11.20 @ 128
Looking at getting a set of Weld RTS 71's 17x5 & 17x10's with a 305-45-17 dr
Sitting at 720rwhp @ 9psi
CorvetteBrent (08-10-2018)
I have found a degree of gear noise with the motive 3.90 from the get go despite being properly set up. Hasnt become any worse. If it is, then there is a problem. Few seem to know how to set up these rears properly. I had a lot of issues with mine.
I went with the 3.90s as the rearmounts are a bit laggy. Should be less of a problem with the cerntri.
If it is spinning too much at launch, 1st and second Then back off on the gear. You have enough power to go with a lower [numerical] ratio.
You can calculate how any change will affect your shift points and MPH per gear
I had 4.10's in an m12 with 611rwhp and did not like it. Drag radials is what I had to run on the street to use 2nd...1st still got no traction and 2nd wasn't great.
I just increased the power and did the trans. and went back to 3.42's.
The 4.10's were fine when it was a cam only car, but too much once blown. Sounds like you are where I was not long ago. I went 3.42's
The following 3 users liked this post by Water_Walker:
What is the car used for? Maybe that needs to go into the decision making equation.
Some good info here:
http://www.badasscars.com/index.cfm/...rod/prd398.htm
https://xse.com/leres/z06/calculator.html
Personally I’d use the 3.42 if its a street car. Makes it easier to cruise the highway and put your power down in the lower gears.
The following 2 users liked this post by Turpid porpoise:
CorvetteBrent (08-10-2018),
Pekka_Perkeles (08-08-2018)
The 3.90's aren't bad at all rolling down the highway in 6th at 70-75 only turning 1800-2000 r's
But yes on some roads in 3rd at 70 you lay into she will light up the rears
I have a buddy here in San Antonio with a 03z that is motor only.
the car has 53k miles. Might be interested in a trade for his stock z06 3rib 3.42.
I just went with a 2.66 tr6060 with the close ratio 5th and 6th for my fi build plan to be around 650 tire for now
thanks Jason
thanks Jason
