pcv system
pcv system
what is the reason for eliminating vacuum hose from throttle body to passenger valve cover pcv system done when supercharger was installed it is an A/A V2
the problem i am having is oil blowing out blow off valve. This happened running a very tight low speed auto cross and never getting out of first gear also i am running a 4:10 gear so RPMs were high for entire run. engine runs great and boost seems good with no unusual noise
