KKs 427 98mm turbo FRC build
Old 09-19-2017, 11:36 AM
02402ramair
02402ramair's Avatar
Default KKs 427 98mm turbo FRC build
I was finally able to make some hits on my new build. I am very happy so far. The car is going to fly once I am able to add more power. Here is a little about the car. I plan on doing some of the small tire racing. Can't really give away the times but they are looking like I might have something to run with the local small tire racers.
2000 FRC
427ci RHS 11.0cr
Allpro 12-4 solid roller
Holley Hiram
Holley Dominator ECU
RPM glide/9"
GTX5533R Gen2 98mm turbo
5" exhaust with muffler
Leash boost/bump with C02
Old 09-19-2017, 11:41 AM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Looks Killer, Kris! Best of success with it!
Old 09-19-2017, 11:46 AM
02402ramair
Couple more pics
Old 09-19-2017, 12:15 PM
Turbo-Geist
Turbo-Geist's Avatar
Looks great. Any run time on it yet?
Pay close attention to those plastic push to connect hoses for the waste gates. In my experience, they do not hold up very well when subjected to heat and melt. I'm planning to use braided hose or hard line this time around on all boost control lines in the engine bay.
Old 09-19-2017, 12:26 PM
02402ramair
I had straight fittings on some and the heat melted the line. I put the 90s on and it helped because the plastic 90 did not transfer as much heat to the line compared to the straight fitting. I have some clear high temp line to try. It is suppose to take more heat. I test the system to make sure its holding pressure on the C02 side before each run. I would like to have AN line and that might be in the future.
1.24 60
141mph in the 1/8 on 18lbs
It has lots more to go.
Old 09-19-2017, 12:29 PM
02402ramair
Having a hard time loading video. Photobucket is what I use to use but its add city and can't get it to load from my phone.
Old 09-19-2017, 12:33 PM
Turbo-Geist
Your numbers sound very promising congrats.
I'm not too worried about your CO2 side. Lose the reference line to the bottom side of the waste gate and it could cost you an engine. Ask me how I know. Just trying to help out.
Old 09-19-2017, 12:43 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
I have yet to find a photo site that seems to work for me, but, for video, I just use YouTube.
Nice numbers so far.
Old 09-19-2017, 12:55 PM
Brice Peters
Brice Peters's Avatar
Damnnn that is clean! I wouldn't want to risk dirtying up that car
02402ramair (09-20-2017)
Old 09-19-2017, 02:19 PM
junk c5
junk c5's Avatar
Killer build.
Old 09-19-2017, 04:00 PM
algZO6
algZO6's Avatar
Awesome build, buddy!!
Old 09-19-2017, 04:45 PM
SBCGENII
SBCGENII's Avatar
Sounds like it going to be fast. Looks good too. What fuel are you running?
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Kris build look great buddy glad the turbo is working. Didn't see you guys in BG KY this month. Car looks good man.. Robert
Old 09-19-2017, 05:49 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Looks incredible! "Lots more in it" is an understatement. I'll bet it goes 160 minimum in the 1/8 if you step on it.
Bret
Old 09-19-2017, 06:28 PM
lobamotive
lobamotive's Avatar
Easily the baddest C5 engine bay I've ever seen. Where did you find the room to mount a muffler?
Old 09-19-2017, 09:11 PM
TheCartel
TheCartel's Avatar
Thats ****! Whose engine cradle and a-arms is that?
Old 09-20-2017, 12:17 PM
02402ramair
Looking into AN line now. I don't care for the push lock but it was easy. Hard line probably be best.
To KKs 427 98mm turbo FRC build
Old 09-20-2017, 12:19 PM
02402ramair
Thanks just tying to be like you.
Old 09-20-2017, 12:25 PM
02402ramair
I was on pump E85 but was going to run out of fuel system once I turned it up so instead of buying new injectors and such I changed to C16. Holley 160s is what I am running now.
Old 09-20-2017, 12:28 PM
02402ramair
Thanks Robert. I have missed LS Fest the last several years. Sucks cause I really enjoyed going and hanging out with everyone.
Quick Reply: KKs 427 98mm turbo FRC build
