Opinion on loctite on the crank bolt
I've removed the stock bolt, pinned the crank, and reinstalled the original bolt but I did not put loctite on the bolt do to all the stories I've heard about not being to get it back off with loctite on. I pulled the stock bolt and didn't see loctite on it, and it only went after several doses of PB BLaster and an industrial impact gun.
So, I placed the new bolt in place without loctite and am just wondering, while I still have the clearance and opportunity to get to the bolt, should I put loctite on, or just let the heat treatment of the bolt and torque of the impact gun be enough?
You only reused the stock bolt to put the balancer on then removed it right? Then installed a new bolt and torqued it properly? All the new stock bolts I have seen had something already on the threads. If you do the proper torquering technique you will know if the impact you have will be enough.
Just figured I should ask some people who've done it. I usually loctite these kinds of things, that's why I ask.
The stock bolt should not be reused.
Crank Bolt, Crank/Balancer Pulley Bolt LS1/LS6 5.7L New GM, when replacing the crank/balancer on an LS1 motor the bolt has to be changed every time because it is a torque to yield bolt (meaning it stretches and can't be used again).
Proper torque is 250ft/lbs or 37ft/lbs + 140* additional rotation
You will be fine. I've had a couple of new bolts on my car for cams and supercharger installs. I've never used locktite. I have read some nightmares about locktite stripping cranks threads. Now that it's pinned you are even more secure.
SCALLOPED91 (06-26-2017)
My ATI balancer came off twice with an ARP bolt and no locktite using the ARP lube and torquing it to 245lbs.
I pulled it, keyed it, cleaned the crank threads and the bolt with brake parts cleaner then used Locktite 262. Hasn't moved since
You're good to go with pinning it. Loctite works out sometimes it seems, but brings nothing to the table if installed correct and pinned.
I went through hell getting my mustang foxbody's crank off, then back on again during its blower install, but I used loctite on it. I've always put loctite on all those kinds of things. Beings this is my first blower installation on a ls1, I got a little torn hearing and reading about their fickle nature in this matter.
I do appreciate the input.
Yeah, the pinning went great; the sucker tapped into place nicely and went just passed the balancer and bolt seating area as described for no bolt interference.
Oh Jesus, that had to be a blast! I of course mean that very figuratively. Did the pulley go too, or were you fortunate to not have it come off?
OEM bolt does have some locking compound on it when new, and you are supposed to only use them once.
That said I have used them before more than once and I did put loctite on it. But best to buy a new one.
Even now using the ARP bolt, I still loctite it. The huge f'ing torque these go to, the loctite has never been an issue for removal versus that damn torque !
I dont think I've ever tightened one up to the correct torque. I'll go as hard as I can with a regular 2ft 1/2" bar, and that feels huge ! I'd be scared of it ripping the threads out.
Although I think torque for much later bolts is a lot lower than earlier cars ? Still huge though.
So, I'm left with not knowing and that is scary. Anyone have any thoughts, suggestions, etc...?
