Dipstick detached inside head unit
I've been running an A&A self-contained oiling kit on my 2000 for a couple years. Was doing an oil change on the unit and find that the dipstick was missing from the brass fitting. Called A&A for suggestions and after verifying the dipstick is aluminum they said about the only way to get it out will be to remove the unit and turn it over. I tried the tweezers I had on hand but it's too tight to get in there. I can see it in there.
I asked A&A if running it with the dipstick in there and they referred me to Vortech who said it shouldn't be an issue since it's long enough to stay in the shaft. Doing a search, this doesn't seem like a common issue. Anyone have this happen? Not happy about having to pull the head unit but at least I can get my AC serviced while it's out.
Had it suggested to either try blowing or vacuuming it out. I think either might work but I won't try until the next oil change. Made a couple passes on the drag strip and no issues seen.
