Boosted Z's how many miles on setup?
Had mine on the stock bottom for 10k miles before going with more boost and deciding to do a forged bottom end along with it. Original setup was perfectly fine with no issues whatsoever at 10# boost before I had it taken apart.
Location: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
mine has 30 on the boosted setup and has well over 2500 passes at the track, have pushed 21 psi at the track, stock bottom end and heads. Never had an issue.
i know a guy with ls3 that has stock A&A kit and meth, makes 630whp and has I think 40k miles on it since the supercharger and he road races it sometimes etc so he beats on it. drives like stock.
started my turbo build March this year and made 515whp/515ftlbs at 12psi stock LS1. Later change out the fuel pump, Hotwire fuel pump and upgrade a few little things. retune on the street so no new number. But since the build being done in March to now. I have put on about 25k KM. Motor has about 214k KM on it.
Mine is a boosted forged LS6 the motor has about 13,000 miles on it.
I just changed the oil (Using Amsoil) for the amount of pounding I give it, I was expecting a lot of abnormal metal particles on the end of the magnetic drain plug. To my surprise, it was minimal normal. It must be the oil and tune together.
