4l60e looking to make 1000hp
Old 02-19-2017, 06:05 PM
03z06u
03z06u's Avatar
Default 4l60e looking to make 1000hp
Hello guys does anyone run the rpm built lvl 10 4l60 and make 1000 rwhp just wondering how long it will hold up and if a lot is doing it.
Old 02-21-2017, 12:51 AM
Chris Stewart
Chris Stewart's Avatar
After burning up several 3/4 clutch packs on my RPM Level 7, I upgraded to the Sonnax smart drum that is the key to the Level X. The drum design is so superior I have confidence it will last longer, but only have 1 season on it. Planning to push well over 1000. I've seen claims the drum mod is capable of holding 1500rwhp, but didn't say how long. It's the best available, so I'll live with it. Other trans options are just too much $$$ for me right now.
Old 02-21-2017, 11:52 PM
c5mtl
c5mtl's Avatar
I've got a level 10 and I held up just fine to a 8.8@157 pass and shifted fine....unfortunately I fried the clutch packs due to tuning error ....changed clutches and now gonna try it at over 1100rwhp.....level 10 or level 100 they will all need clutches sooner or later. At this hp level consider it maintenance
Old 02-22-2017, 01:12 AM
C5Natie
C5Natie's Avatar
My 4L65E was built by a friend who has been doing it for many years and he used the Sonnax Smart Input drum as well. The car has been putting down close to 900rwhp with no issues. I recommend a quality lockup converter like a Circle D and the biggest cooler you can fit.
Old 02-23-2017, 09:03 PM
03z06u
03z06u's Avatar
Thanks guys I was wondering if I should just buy a c6 with a 6l80 since everyone saying there going 8s on stock trans. Wonder what's stronger 6l80 or built 4l60?
Old 02-23-2017, 09:27 PM
Chris Stewart
Have you seen this thread? They are talking about a 4L60 swap as being an upgrade, due to more aftermarket parts.
First pass with YSI = broke 6l80 case
Old 02-24-2017, 11:25 AM
algZO6
algZO6's Avatar
i beat the crap out of my level 7 for almost 5 years. 3-4 clutches went out so i did a refresh and upgraded to a level x.
smokinstorm (02-25-2017)
Old 02-24-2017, 05:38 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Level X from RPM you will love in the car. Key on it is making sure also the trans level to correct.
The guys at RPM is the only way to go on these cars. Rodney & Todd are great. I will say here the shop is better on help after the sale as when you are buying the item at purchase.Robert
Old 02-25-2017, 09:13 PM
smokinstorm
smokinstorm's Avatar
Level X RPM is certainly the way to go with 1000 or more RWHP but I just bought two sets of tires from a gentleman (Eric Fox) making over 1000 to the tires in his C5 Vette and races it regularly and his Level VII RPM hasn't failed him. Yet. We're stepping up to ~1000 RWHP for now and am going to keep the Level VII until it fails and then upgrade to Level X all from RPM when either it dies or we step up the power substantially. We're fairly light now so I hope that helps.
Old 02-25-2017, 09:15 PM
smokinstorm
Details on car if you don't mind sharing??? Power? Track times? Weight? Slicks or radials? Rear gear? Converter?
Old 02-25-2017, 09:18 PM
smokinstorm
I sure hope the claims of holding 1500 RWHP are accurate. We're not going to make quite that much but having margin for error is never a bad thing.
Old 02-26-2017, 02:22 PM
Chris Stewart
Here's where I found the 1500hp claim. If it's not true we will riot haha. Adding the url for info, but you'll have to copy/paste since they don't like links to non sponsors here.
transmissioncenter.net/shop/700r4-4l60e-4l65e-4l70e-loaded-smart-tech-input-drum-with-billet-input-shaft/
Old 02-26-2017, 09:22 PM
CamminC5
Support Corvetteforum!
CamminC5's Avatar
St. Jude Donor '15-'16-'17-'18
I have a RPM level X. Car makes 900 to the ground. Had it for a year with no issues.
Old 02-27-2017, 10:50 PM
smokinstorm
Product description looks very compelling. A friend of mine is making 1150 RWHP in his Corvette with success with an RPM Level X transmission and he's a lot heavier than we are so I know he's putting a strain on it. Jeremy at RPM said their Level X is good for 1100 RWHP in a Vette with no problems but there were people out there making quite a bit more than that. He said it needed to be rebuilt with alarming regularity at those elevated power levels though. I just truly hope it'll hold 1200 or so to the tires for maybe 50 1/8th mile passes.
Old 02-28-2017, 10:08 AM
algZO6
algZO6's Avatar
it hasn't been on the dyno with the latest setup. its a basic forged 365, 220 TFS heads worked over by Tooley, Tooley cam, FTI stall, 3.42s, on a 275 pro. best time in 5000' DA is 8.84@154. she's a heavy girl, nothing taken out plus a 6 point, amps, blower, ect. Last time i weighed her she was almost 3700.
Old 02-28-2017, 11:11 AM
smokinstorm
Wow, that motor is making a LOT of power to run those numbers at that weight in that DA. Sounds like 1100+ RWHP to me as this is about how my friend's car with 1150 RWHP and similar weight runs but in better air. You're sure putting the transmission to the test. I'm feeling better and better about the 4l60e holding up for a few passes with what we're getting ready to throw at it. What supercharger are you running at what PSI?
Old 02-28-2017, 11:44 AM
algZO6
algZO6's Avatar
i run a ysi-b. i was having some belt slip issues so i only saw 15 psi on that run. all belt issues have been resolved since then. i took it to houston and in -1100 da i saw 30 psi, that's when the stock ls2 intake blew to pieces.
To 4l60e looking to make 1000hp
Old 02-28-2017, 07:06 PM
smokinstorm
HOLY CRAP! -1100 DA, 30 PSI. I hate to think how much it was making at that instant but I know it's so far beyond 1100 at the tires that you can't see that marker from where you were at. 1300? 1400? Neither seems out of line given what you just said. Well done, Sir. Well done. I'm going to have the LS3 style Mamo ported FAST 102 LSXR installed before we shoot for any real numbers. Hopefully it won't go BOOM!. I only want around 1100 to the tires until I get a 6 bolt motor done.
Old 03-01-2017, 03:21 PM
03z06u
03z06u's Avatar
What pulley was that to make 30 psi ?
Old 03-01-2017, 04:59 PM
algZO6
algZO6's Avatar
2.85"
Quick Reply: 4l60e looking to make 1000hp
